Results 1 to 15 of 17
Thread: Head Gasket Problems Please Help
    my head gasket has leaked for a while and now a head bolt stripped out and so i put a helicoil in it so it should have stopped leaking since it is tight but i went to go buy a new gasket and the guy told me to paint both side with silver spray paint and it seemed to work(MY HEAD GASKET IS COPPER BY THE WAY) but afer a while it started leaking again so do you think that the gasket got wore from it leaking for a while or do you have any other tricks to stop it from leaking or should i just get a new gasket its only $10
    81 yt125 tri moto
    YAMAHA Snow Dirt Or Grass Yamaha will kick your A**
    Ashland City, TN
    2,576
    I would say just buy the new gasket instead of d!cking around with this old one.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Feb 2003
    84
    save yourself the hassle and buy a new one
    IT WORKS NOW!! GO HERE
    http://www.geocities.com/bjh200x/PHAT_TRIKES.html
    1985 250R- all stock
    1985 200x- complete restoration
    1984 ytm 200- huntin rig
    :Beerchug
    Rittman, Ohio
    6,276
    For trying to save $10, you are risking melting a hole in your piston. Copper gaskets compress when you torque the head down which is why youre not supposed to reuse them. If you vere use a sealer, dont use paint! Use Copper Coat gasket sealer, which is a spray on copper film specially made for metallic head gaskets.
    May 2002
    610
    What kind of witchcraft is using silver paint on a head gasket? Use a fresh gasket so you can get all the compression yer engine can make. This is just my opinion.
    Sam from Florida
    1985 BIGRED $ 200X
    Nov 2001
    136
    If the copper sealant doesn't work, you may have a warped head.
    '85 225DR...'85 200E Yamahauler...'83 YT125(complete engine rebuild)...'82 & '81YT125 for parts...'80ATC110
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by YamaChuck
    I agree 100% there. I use the coper spray all the time and it seals almost all the time. But once in a while it won't because of warpage.
    Howdy
    Jun 2002
    Mississippi
    2,552
    especially if the head is warped and i would do this anyway.. take a peice of thick flat glass and lay a peice of 600 grit sand paper on it. put a dab of dawn soap on it and some water. now lap the bottom of the head in it in a figure "8" motion. do this until all of the seating surface on the head is shiny. it may take several sheets of paper to do this. i usualy stop at the 600 grit but going on up to 1000 grit would be better. now you are sure you have a flat head.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Nov 2002
    132
    This is what I would do.
    If the copper gasket doesn’t have visible sings of damaged, try this. Use a torch to heat the copper gasket up to the point that it is glowing, this will expand the gasket to its original size. Not now you can install it; I use Paratex High Tack Gasket Sealer to help insure a complete seal.
    Feb 2003
    137
    THIS IS REDICULOUS!
    BUY A NEW HEADGASKET ALREADY!!!
    (please)
    G-MAN-1 is offline Just Too Addicted Arm chair racerJust too addicted
    lol
    really just go buy a damn gasket and stop f---ing with it. i hate people who try to save 10 buxx. and end up messing up 200 bux plus worth of other sh-t. up. geeeeeeeeeeeeeeeeeeeeeeez. dont be a cheapo. :evil: :evil: :evil:
    Nov 2002
    132
    Just for information, copper head gaskets are made to be reused, just heat them up and they will expand.
    FullBore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    You may be able to reuse them, but why when a new one is only $10??
    Its better off with a new one, If you’re doing something that’s worth the effort, its worth doing Right!
    If its right the first time there should be no second time!
    1979 Suzuki TS100
    1984 ATC70, Broke
    1984 ATC110, Repainted and Rebored.
    1990 Suzuki SJ410
    Unsuspended Antics.
    Nov 2001
    136
    Just for everyone's info, I had the exact same problem with my head when I rebuilt my YT125 motor. I bought a new gasket 3 times and used the copper sealant with no luck. Then I finally did as basket said and sanded the head using sandpaper and a thick piece of glass. That did the trick. Heck, I got the idea right out of my service manual. It works!
    I just ordered a new gasket yesterday and if it doesnt seal ill try the cleaning method or if the head is warped i have another one so ill try that
    thanks for all your help 8)
