Thread: Trike doesnt work in cold
    Sep 2005
    Saskatchewan(Moose Jaw)
    769
    Question Trike doesnt work in cold
    Well, well probably be getting snow with in 2 months, an that mean cold weather. When I rode last year my trike would only work to -15 weather, anything colder than that, it would die when you gave it even a little gas. I thought it might be jetting but by the sounds of what people say it might not be the jetting. Any body have an idea of what could be wrong and how I could fix it?
    Current Rides
    3 skidoo's, 1 quad, and 1 trike
    http://www.cardomain.com/ride/2679723
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    Only thing i could think of is.
    1. go with a much thinner oil.
    2. try to warm it up real good without gas. (idle warm up)
    3. maybe a hotter plug?
    4. make sure your gas isent frozen, or your lines arent frozen.
    I would do number 4, it could be partially frozen and not getting enough gas.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    florida
    2,328
    hey clint did u try moving *Edited**Edited* clip 1 or two notches down to ritchen the mix up a lil bit
    Sep 2005
    769
    I was going to try that Stephen but then a couple people said it might be my engine isnt getting hot enough or something. So I thought before I go to the crabby Honda dealer and spend money on jets I would ask here first.
    Traxx, when you say thinner oil, you mean in the gearcase? Im using a 4 stroke for riding just so you know.
    Ill try the idle thing, ill let it idle for 10 minutes or more
    If anybody knows a hotter plug than RA6HC let me know please
    and I know it isnt that the gas is freezing, I had that trouble at the start of the year, when I was putting gas in it some snow blew into my gas tank and melted,so I had frozen water gas, so I cleaned the carb, emptied the gas and put gas-line antifreeze in the tank, so I know it isnt frozen gas either. Thanks.
    Current Rides
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by 85hondaatc125m
    Go to canuck tire and pick up a litre of AMS OIL 0w40 4 stroke Atv oil, Make sure your carb is clean, No water, and set proper, And use the choke, it should start, my Old Atc 90 started in -35 here no problem.
    1985 Tri-Z-
    florida
    2,328
    i dont live in canada but seriously canadian tire should change theyre name to canadian rip-off
