Results 1 to 9 of 9
Thread: Alright, carb, cleaning, and how to?
    May 2005
    chino CA
    62
    So, my darned ATC wouldn't start the other morning. went out, gassed it up, and gave it a good kick. only to discover it leaking gas out of both drain/vent tubes. So i figured the floats were stuck or something.
    So i removed that carb, took the floats out, and the little valve. and squirted some carb cleaner in the. floats did seem to be a Little stuck. reinstalled and no more gas leek. but, still no start.
    So i squirted some gas into the carb opening (where the air filter attaches) and it fired right up for about 3 seconds. and continues to not start unless you put gas into that carb.
    So anyone have any tips on the best way to clean that carb? and the best way to readjust everything afterwords?
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    Did you remove jets and check them? Sounds like pilot jet is clogged.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    May 2005
    chino CA
    62
    I did not. i didnt want to screw with any adjustments and have the thing not run right again, ever. i guess i will though
    crackshot's Avatar
    Idaho
    1,024
    What is this carb off? Model?
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Aug 2006
    NEBRASKA
    9
    Clean everything, pull out your jets and make sure the holes are not plugged. The gas was dripping because of your needle and seat, if it hasn't been replaced in a long time it should be done.
    leroy, new york
    1,025
    sounds like needle is getting stuck closed. get a little pipe cleaner and some carb cleaner and clean it out.
    May 2005
    chino CA
    62
    carb is from a 83 200x
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    yea dude its your jets, the two gold looking things. take then out hold em up to light if you can see any light thru them theres your problem. usally you can get them with jet carb cleaner blasting it out. somtimes there a lil harder.i always got a brake wire off a bike and split the end very long, (one single strand off the whole thing), and used that to fit into it to clean it out.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Jul 2004
    Mud hill. close to water !
    3,658
    carb cleaner and compressed air !!!
    take everything apart... and clean it carefully..
    the only screws you have to be careful with are the flat head scres for the air/fuel and the Idle screw...
    the rest just go in and out..
    Be careful when taking the float out not to bend the little tab that sets the float level.. take your time and don't force anything.
    Clean all the little holes and blow air thru everything... specially those jets !
    http://www.3wheelerworldforums.com/s...ad.php?t=56649
    this is a jet.. just been thru this myself this weekend !
    Currently :
