ok i have an 85 tri-z and it runs great and has plenty of power but it just seems to go through the gears and top out way to fast, i looked at the sprockets and saw that the front is a 13 tooth sprocket the rear i am not sure about but i will assume it is stock not sure how many teeth they are stock. so i looked around for different sprockets and saw there are many options for the front sprocket ranging anywhere from 11-18 teeth now i know i want to stay away from the smaller sprockets but what would you guys suggest i start at since im running a 13 now i was thinking 15-16 tooth but will that be too much or too little to notice a change in top speed without killing all of the low end.
