Results 1 to 8 of 8
Thread: Spark plug issue
    Mar 2004
    NE Indiana
    497
    Spark plug issue
    Ok, I got brand enw plugs for my 200 about 4 days ago. I out one fo them in 2 days ago, and rode it all yesterday. Today it wouldn't start, and when i took the plug out, the tip is all black. What the hell could cause it to foul so quickly? It backfires some, and I'm pretty sure the timing is on.
    Also, does anyone know a quick, redneck way of fixing a leaking valve stem? I slathered it with super glue, and it half worked, but I need the other half full of air, lol.
    1985 Honda 250R
    1986 Yamaha Tri-z
    1984 Honda 200s
    1983 Honda 200x
    1982 Honda 200
    Pa.'s Highest City
    8,058
    You may just have some dirt in the stem causing it not to close properly. Good luck getting that out now that you've glued it. There is a special tool for them or sometimes the aircap itself has the tool built right into the top of it.
    As for the black on your plug that sounds to me like your runniing rich. you might have to lean it out a bit.
    Mar 2004
    NE Indiana
    497
    Nope, the guy before me had put a tube in it, and found it it wasn't gonna work because the tube wasn't going ot line up properly, so he left it. well i aired it up, despite knowing it, and after a day, valve has a leak some wear around the base. So i've been trying to plug it using super glue.
    1985 Honda 250R
    1986 Yamaha Tri-z
    1984 Honda 200s
    1983 Honda 200x
    1982 Honda 200
    Mar 2004
    NE Indiana
    497
    And waht color is the exhaust when it's running rich? Blue? if so then, yea, it's running rich. But I know absolutley nothing about carbs, so what do i adjust?
    1985 Honda 250R
    1986 Yamaha Tri-z
    1984 Honda 200s
    1983 Honda 200x
    1982 Honda 200
    Pa.'s Highest City
    8,058
    Quote Originally Posted by bassman
    Lol... I'm still learning myself...
    This link is very helpful.
    http://www.3wheelerworldforums.com/s...ad.php?t=55086
    Oh, those stems can be found at your local atv shop or automotive store cheap. Might just replace it. OR tire slime might help in this situation... but it's messy.
    Mar 2004
    NE Indiana
    497
    ok, thanks alot!
    1985 Honda 250R
    1986 Yamaha Tri-z
    1984 Honda 200s
    1983 Honda 200x
    1982 Honda 200
    Albion Il.
    59
    You can't fix a cut valve stem.
    If you cant seal the rim there is a tube with the valve stem
    in the proper place . I work at a goodyear store and we
    have to order these sometimes .
    The rim isn't always the problem as old tires leak thru the
    casing.
    C n H
    1981 200
    1985 200s
    1982 185s
    1986 110
    1986 200x (parts)
    Three Wheels Burnin'
    Mar 2004
    NE Indiana
    497
    Sweet, how much are those tubes then? I pmed howdy tog et new rims off of him, but heck I might aswell have these up and going.
    If it matters, my tire size is 25x12x9.
    1985 Honda 250R
    1986 Yamaha Tri-z
    1984 Honda 200s
    1983 Honda 200x
    1982 Honda 200
