Results 1 to 8 of 8
Thread: ATC110 front rim options
    Pete is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2003
    Lino Lakes, MN
    229
    I have an '82 ATC110 that I'm looking to get an aluminum rim to match my rear rims. Are there any options out there for such a thing, or would it be a custom Douglas order (aka, $$$)
    Here's the reason I ask, I desperately would like an aluminum front rim and 18 inch turf tamer to match my rears...
    springville, PA
    6,185
    A suzuki 230 quadsport front rim will fit, then you can have a skinney front tire up front for better steering.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Apr 2006
    PA
    1,464
    I think i saw them before in dennis kirk? Maybe rocky mountain atv? im not sure but how do thoes 18s slide compared to the stock baloon tires.?
    Dec 2003
    Lino Lakes, MN
    229
    Quote Originally Posted by super90
    alot better, I also have 200X hubs on it to widen it out some, but with the huge front tire it pushes alot due to the rear weight bias.
    Nov 2002
    Kirkville, NY
    3,831
    Someone one here is running an atc 250R front hub/wheel combo. Then you get the nice narrow front tire and a polished aluminum rim.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Tionesta, PA
    5,743
    Cool looking trike. What size rear rims and tires are you running on that mean little machine?
    Dec 2003
    Lino Lakes, MN
    229
    it has 18 inch turf tamers on some sort of rolled bead 8 inch rim. 4x110 pattern, I'm running 200x hubs to widen it out. I used to have a 250R front axle and hub, wish I had kept it now...
    Apr 2006
    PA
    1,464
    I put a 250sx? front wheel and axle on mine before with a frontmax tire. It was nice compared do the baloon tire. You could whip it around alot better too. And there was no more front tire sliding when i tried to turn. But it needed to be wider.
