Thread: PWR Radiators
    Jan 2004
    NJ
    1,646
    PWR Radiators
    Has anyone upgraded their 85/86 250r with aliuminium radiators? Any problems with the fit on the brackets? Any clearance problems? Thanks
    3 CR500R's and counting. Do I really need 4???
    Do I really need 9 Tigers?
    Laegers ATC500R
    DO NOT send any thing to whats his face (dirt-face/crasher) here on the board. What a scum bag. He screwed (stole) money from me and screwed me on my ME360 and Hondaline 300R engine rebuilds.
    Jun 2003
    englishtown NJ
    2,676
    I have them on mine and they fit good w/ a short track kit, I can't imagine any problems with stock front ends.
    bushwacker51 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Cherokee, Oklahoma
    267
    Are the radiators bigger then the stock radiators and did you notice if the trike ran cooler with the aftermarket radiators. i think those radiators are 3-50-400 bucks. Thats alot of money to see no to marginal results. thanks for any additional information Glenn O
    Jun 2003
    englishtown NJ
    2,676
    I never ran it yet, I bought them so I could have new radiators, not ones with bent fins and stuff, they are thicker than stock. They go alittle bit more forward and very little back. I'll let you know if they run cooler when I finally get a chance to run them, wheather here is kinda bad now. I know the pwer radiators work far better on quads, I'd imagine similar results on the atc's.
    Aug 2002
    New York
    1,098
    Hey Deathman....do they work? I just bought a set. I'm curious if they drop the temp at all. They should.
    I remembered that you had a short track kit too. It's great to hear that they will bolt in without a problem.
    Jun 2003
    englishtown NJ
    2,676
    They cool better, it was nice to have new radiators. Wheather they are worth the $390 depends on how your radiators are. I am running a hot running motor and on hot summer days, it runs about 180, slow trails and such around 200. They do take longer to heat up the bike and the bike takes awhile to get to around 200.
    I think they were worth it, especailly if you have a real hot motor(big bore, alot of porting, hotter spark etc), but if you have a stock motor, they aren't worth it. Pretty much the same as with trx's, if you have a stock motor, a stock radiator is fine, but a highly modded motor needs a pwr or equivealnt brand oversize dual pass radiator.
