I found this BBR carb kit on DennisKirk http://www.denniskirk.com/jsp/produc...&mmyId=5800069
Will it work with an ATC 110 engine? I think it'll be a good idea, I'm kinda building that thing to be a beast, probably w/ a K&N and a Yoshi pipe.
I'm back in the USSR...
isn't that a little big for a 110?
Rest in peace Rex Carlson
Well a guy on here named crackshot wrote that he used a 24mm carb with his 110... maybe it is a bit big. With just a pipe and filter, you think this 18mm one will be enough? http://www.denniskirk.com/jsp/produc...&mmyId=5800069
The awesome thing is that it comes with a twist kit as well, which I wanted to put on there anyhow.
Why not run a Atc 185 carb.. bolts right up.
The carb size sort of is related to how many ccs' you are running. You can run the 26mm carb on a 110 and jet it down, but your bottom end will suffer somewhat. If you are running that 110 wide open all the time it will give you more top end, but if you are running trails through the woods, the carb will give you less power on the bottom end. I have a bored and stroked 110 that is running a cb750 piston and I'm running a bigger carb than that, but it is not on a trike that sees much trail riding and it will bog down at lower rpms but it is a blast with the throttle opened up.
