Results 1 to 15 of 24
Thread: suzuki alt50 mod ideas???
    Aug 2006
    Blaketown
    35
    Arrow suzuki alt50 mod ideas???
    i have a 1984 suzuki alt50 and i was wondering if anyone has any ideas to mod it, both performance and looks,i was thinking about gettin a suzuki jr50 engine as it has gears, and using my top end, any thaughts, and also what about
    -black tank
    -white frame
    -snow camo seat
    -white rear fenders
    -back front fender
    -gold ,rims and bars
    -maybe gold engine
    Any body think this would look any good?
    Rittman, Ohio
    6,276
    Why? Its the smallest of the mini trikes, and have more motor than a child of the appropriate size for that trike can handle as it is. They are also extremely rare, and modfications destroy their value. Id preserve it or sell it, and buy what you want.
    Aug 2006
    Blaketown
    35
    i would keep the bottom end off the engine i have now or find a top and, plus the jr50 engine will bolt right in without any mods
    Mar 2004
    Eastvale, CA
    630
    Lookswise I'd restore it to original but if you want to get a few more beans out of the motor there are some things you can do. I made the following mods to my sons Kawasaki KFX50 quad (same motor as the ALT and the LT50 quad) and they really help. When it's all done and back together the only things that are visible and give away the mods are the aluminum silencer and throatier exhaust note.
    1. Remove all restrictors. There's one for the carb where it bolts onto the little elbow shaped intake manifold and one in the cylinder where the exhaust bolts on.
    2. Put a K & N air fillter and Outerwears on. You have to modify the plastic air box and a motor mount to accept it, but it can be done. Use filter
    #RU-0200.
    3. FMF makes a pipe/slicencer combo for that wakes it up a little. It doesn't have an expansion chamber, but it does help.
    4. Rejet the carb. A must do if you make the air fliter and pipe swap. Replace the #55 main with a #75 and remove one of the stacked pilot jets.
    5. Eliminate the oil injection system and run pre-mix with a good synthetic oil.
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Sep 2005
    Lipetsk, Russia
    2,824
    Quote Originally Posted by Mr. Sandman
    CT Racing makes an expansion chamber pipe and silencer for the LT50/KFX50 which would probably work.
    I'm back in the USSR...
    Aug 2006
    Blaketown
    35
    thanks for the tips, i would rather have an expanshine chambre so i am going to check out ct racing, thanks alot, any one else got any ?
    Sep 2005
    Lipetsk, Russia
    2,824
    Quote Originally Posted by minitrikemania
    I remember reading in ATV Action a while ago that you can run some kind of special oil in the tranny of the LT50 to keep the clutch from burning out... I'll look and see sometime today.
    Aug 2006
    Blaketown
    35
    i was on some forum earlier today and it was about making a boost bottle so i got to thinking, ,my trike doesnt run on the vacum any more so i removed the cap off the vacum inlet and made a boost bottle out of a castrol oil container, but it was to big and calumsy so i exchanged it with a smaller shampoo bottle, the boost bottle realy does make a difference in the bike, it gave me alotmore power and acceleration but it didnt gain to much speed, i also made a custom exaust today which i will install some day this weekor next week, i think id rather find another exaust first thos so i dont have to cut my header, and so that if the exaust doesnt work out to well i dont have to weld up the stock exaust , also does anybody think a white frame would look any good on the bike?
    Sep 2005
    Lipetsk, Russia
    2,824
    WTF. How would a boost bottle help on a single carb machine? I thought that a boost bottle was meant to equalize pressure between the carbs on a twin carb machine?
    On another note: Frame color is directly dependent on plastic color. Personally I think if you made the frame white, it would get boned too fast. Use a dark frame color and a light plastic color (i.e. black and white, blue and white, blue and yellow, etc)
    Aug 2005
    HI
    1,575
    people have been using boost bottles on the early atc250R's and tri-z's for racing A LOT. Those were big back then. Don't really know to much on how they work, but i do know that a lot of people used them.
    Rest in peace Rex Carlson
    Aug 2006
    Blaketown
    35
    ya i think i mite do that with the colours, ya i thaught the same thing until people started to use the boost bottles on gas scooters and pocket bikes , the ones on the single carb collect the gas which doesnt go into the motor and that basically goes back into the carb and holds it untill needed it makes it easier on gas and improves performance alot on the single carb machines
    Lead Follow Or Get The Out Of The Way
    1992 yz250, needs top end done F/S
    1997 KDX220-half pimped
    1984 suzuki alt50 -wants modded
    Rocky Mountain Peddel Bike
    bravo short track
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,248
    __________________
    sorry not even close,,,,, boost bottles deal with positive and negitive crankcase pressure,, not gas,,, when you let off the throttle you have positive pressure in the crankcase. the second you get back on the gas the positive charge (air fuel mixture) is reinjected into the crankcase improving throttle response it also gives you more volume in your intake tract,,,, on a 50cc,,, motor its all in your mind,,,,
    Aug 2006
    Blaketown
    35
    sorry not with the type that i used i read it off of like 5 different sites and off of like 3 boost bottle companys that make them for pocket bikes and gas scooters, and trust me it made a difference with it even if it is only a "50"
    bravo short track
    KASEY's Avatar
    4,248
    sorry but there is only one TYPE of boost bottle,,, and usually the company telling you they work awesome is selling them,,,,,,, do a search and look at engine builders not wholesale scooter parts ,,,, then you will get real world information,,,,, ohh i forgot,,, maybe a shampoo bottle would be different
    Aug 2006
    Blaketown
    35
    bravo short track
