Results 1 to 2 of 2
Thread: left side of motor
    Mar 2003
    left side of motor
    i know im not being very specific but i just got this bike so here it goes.
    on the left side of my 350x the large case directly in front of the shifter
    is seeping oil.i just need to know the name of the gasket so i can replace it.also is there anything i should be lookin out for when replacing it.
    thx in advance
    forsomedamnreasoniamhatedinaz
    Howdy's Avatar
    Celina, Ohio
    10,079
    Re: left side of motor
    Quote Originally Posted by hatedinaz
    thx in advance
    I am asuming your talking about the stator cover. It's sorta round. A lot of times what happens is the chain hit's the case, and cracks or breaks it. ( I have a few broken or cracked ones as proof ).
    I would start by looking real close at the cover where the oil is leaking. See if you can see the cause of it. Once you have a pretty sure idea of the cause then you can go about fixing it. The covers do have a gasket and chances are you will need a new one when you remove it. With any luck it's just a bad gasket causing the problem.
    If the case is broken you will need to get it repaired of find another one.
    I hope I helped.
    Howdy
