I was thinking getting a different sprocket, since the tires are huge and I only use this in the snow, in the mud, hill clmb, work, etc. Oh yea, it's an '82 200 with 25" tires.
1985 Honda 250R
1986 Yamaha Tri-z
1984 Honda 200s
1983 Honda 200x
1982 Honda 200
It will be very noticable, it is on my 400EX when I go from 15 to 14. Also, make sure you have enough adjustment for the chain to still be tight after you drop a tooth on the front.
Travis
My Rags
Yea, but I think I need a whole new chain anyways, I hate using this one. There's a few links that are frozen in its position from sitting, and I left in oil over night one night and it didn't cure it.
1985 Honda 250R
1986 Yamaha Tri-z
1984 Honda 200s
1983 Honda 200x
1982 Honda 200
if you can try 2 teeth
What will 2 teeth do?
1985 Honda 250R
1986 Yamaha Tri-z
1984 Honda 200s
1983 Honda 200x
1982 Honda 200
don't try 2 teeth, try one first.... With 2 you'll loose a lot of top-end and might wheelie a little too easy on the woods trails......
"I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
It wheelies easy as it is. What is the stock front sprockets on these things? It's got an 11 tooth on it right now, but I have no idea if it's stock or not.
1985 Honda 250R
1986 Yamaha Tri-z
1984 Honda 200s
1983 Honda 200x
1982 Honda 200
so its less teeth=more top end, more teeth=more bottom end
on the rear, yes. Just the opposite for the front.Originally Posted by trikes4life
My Rags
