you need to lean out your main....also you cant punch it as soon as you dump the clutch with alky, youre pumping to much fuel into the cylinder, ease into the throttle out of the hole, take about 1/4 of a second to give it full throttle. you will figure it out. you should be all set with that ignition as long as you have it timed right.
