Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 41
Thread: Help/advice installing 250R piston (Installing new piston)
    May 2005
    Southern NH
    1,489
    Question Help/advice installing 250R piston (Installing new piston)
    Got my 310 kit (cylinder and piston)
    Any tips or tricks?? What should i lube the piston and cylinder with? @ stroke synthetic???
    I can get any pics if you need them to help me!
    Thanks, Devin
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
    Jan 2005
    Great Bend
    704
    before you install the cylinder and piston go to www.ctracing.com and read their guide lines to correctly prep and install a cylinder and piston. it is pretty detailed and if you have a question you can call them and they will help you out.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Feb 2006
    AZ
    1,358
    all of mine slipped right in - just make sure every moving part such as rings, cylinder wall and bearing is coated in good 2 stroke oil. The piston should slip right in without much effort if appropriately sized for cylinder.
    I've done 3 of them and all are still operating.
    You might want to take the extra step of checking the ring gap since that is an expensive cylinder. Usually that info is in the instructions of piston kit.
    May 2005
    Southern NH
    1,489
    Can't get the damn cylinder off!!! I sprayed penatrating oil and tapped with a but it won't budge.....
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    This is my own advice but I DO NOT coat the cylinder walls or piston with oil. Bearings, OK though. Its easier for the cylinder to glaze on start up if its coated with oil.
    You got all 4 nuts off, head stay mounts, exhaust, ect removed? I dont know about the Rs but on my 500 I have to take off the exhaust flange or it hangs up on the frame. check that.
    May 2005
    Southern NH
    1,489
    It's off the frame Billy, I'm pushing on the case with my legs while pulling the cylinder with my hands........
    Jan 2005
    Great Bend
    704
    if you have a rubber mallet keep tapping it front to back, side to side, it will come off. it may require a solid but not over powering hit to knock the cylinder loose.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Live Oak, FL
    15,070
    I hate to use the word "pry" but see if you can fit something inbetween the intake and the case and work it around a little bit. Don't use a unless you have a fiber or non marring surface one.
    Jan 2005
    RI
    2,530
    put the kicker on and try kicking
    mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    May 2005
    Southern NH
    1,489
    Got it!!!! Just pryed it by the intake and exhaust, don't worry no damage!!! I'll post pics later! Thanks a ton guys!!!
    Now i have to get the piston off.........
    Sep 2005
    Northwest Ohio(Forest)
    974
    Man that is going to be one hell of a bike you got there 250r'en +TCB!!!!!
    GiT it RaGGGG!
    '86 200x
    May 2005
    Southern NH
    1,489
    WRONG PISTON!!!!!!!!!! What the hell!!! The guy must have sent me the wrong piston, not even sure it's for a 250R, maybe one with and extended rod. it's cleary differnt from the one in the aution picture!! I e-mailed him about it, he has been straight-forward so far with 99.7% positve feedback.
    the piston won't work because it has no space for the connecting rod to rotate! Stock is on the right in these pics BTW
    I sent him these pics too, damn what a pain in the arse! This is what blows about buying on the internet.........
    May 2005
    Southern NH
    1,489
    Actually I just looked at the auction pics, I think it's the same.......
    So what's the deal hear guys????? Do I have to get a +5mm rod or what???
    Pete is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2003
    Lino Lakes, MN
    229
    thats an 88/89 250R piston.
    May 2005
    Southern NH
    1,489
    Ok so where does this leave me????? Do have to get an 88 or 89 connecting rod??? They were +5mm correct???
    What must I buy to get this machine running????
