Results 16 to 30 of 41
Thread: Help/advice installing 250R piston (Installing new piston)
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    looks like your screwed,,, you will have to get a short rod piston,,,, cause a long rod piston won't go all the way to the top of the bore,,,,,,,,,,,
    Jul 2006
    hey man I havea stroker base spacer you can have if it will help, let me know..
    May 2005
    Southern NH
    1,489
    Quote Originally Posted by KASEY
    WTF?!?!?! I would need a longer rod so the piston could complete the stroke, right? Did you get those 2 mixed up???
    Would a spacer plate be enough??? Or do i need to buy an 88 or 89 rod???
    Please somebody tell me what i have to get to make this work!!! Any pics you need I can get........
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    You need a piston that same diameter with the wristpin located 5mm lower or whatever the difference is between the short and long rods, if there is such an animal. Alternatively you COULD cut 5mm off the piston skirt and the bottom of the jug but I dont know how well that would work out...
    May 2005
    Southern NH
    1,489
    Quote Originally Posted by Billy Golightly
    You need a piston that same diameter with the wristpin located 5mm lower, if there is such an animal. Alternatively you COULD cut 5mm off the piston skirt and the bottom of the jug but I dont know how well that would work out...
    The guy swears on his life this was the piston run in the quad with this kit. the piston is a match to the cylinder for sure...... I'm waiting for him to answer me if it was used on an 88/9 engine.
    This piston has defiantly been ran before, so something must work......... Maybe I would have to shave 5mm off the skirt, but that's obviously a last resort...... Hate to have to break out the bench grinder!!!
    Jun 2003
    englishtown NJ
    2,676
    first, what rod do you have, does it say ha5 on it? I use long rod cranks and 86 pistons, I have 5mm spacer plates on my motors. Most of you big bore pistons are 86 pistons(if not all). Esr sellls a spacer plate kit, that includes everything you need. And yes, the head stay mount does work. I believe 87-89 pistons stop at 68mm or 80 over, 86 pistons go to 76mm bores, maybe78mm?
    May 2005
    Southern NH
    1,489
    Here's what the guy said to me, looks like he knows his stuff thank god lol:
    "The window in the piston indicates that it is the long rod, the short rod piston have a half moon at the bottom, thats why i had the oiston positioned with the window showing. if you have a shortrod motor the cheap way would be to grab a crank and rod off ebay i see them for as little as $40.00"
    Is this what i'll have to do?
    Pete is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2003
    Lino Lakes, MN
    229
    you need the '85/86 version of that piston or an 87+ crank. I'd do the piston over the crank, that way you don't have to split the cases.
    Aug 2002
    New York
    1,098
    Well I guess if you wanted to wait another 6 or so months, you could get a good crank for $40. Then have to dig into your bottom end. Why don't you go to wiseco's page to see if they make the same size piston for the short rod motor?
    I looked at LA Sleeve's site. They have them from Pro-X and Wiseco.
    Dec 2003
    Lino Lakes, MN
    229
    I haven't seen a 310cc 88/89 piston in a long time, is this a Pro-X cylinder you're installing, and are you sure the bore size is 72-73.5mm?
    Jun 2003
    englishtown NJ
    2,676
    I thought the big bores only came in 85/86 pistons.
    Jan 2004
    Palmetto,Florida
    2,300
    Ohh...my ..... God !!!.........
    "07" DR650 Suzuki Dual Sport
    Nov 2002
    hinesville ga.
    200
    my question when was the bottom end rebuilt. if you don't know that the go ahead and rebuild it complete. add more compression can cause the rod bearing to end up on top of the piston. ebay: crank bearing, complete gasket kit , complete seal kit under $100.00 a small price to pay for years of riding. since the crank halfs are the same order a 87 to 89 trx crank rod and rebuild the crank... that's what i do. also i coat the cylinder and piston with WD40 when i'm putting it back together...
    Nov 2002
    hinesville ga.
    200
    my question when was the bottom end rebuilt. if you don't know that the go ahead and rebuild it complete. add more compression can cause the rod bearing to end up on top of the piston. ebay: crank bearing, complete gasket kit , complete seal kit under $100.00 a small price to pay for years of riding. if the crank halfs are the same order a 87 to 89 trx crank rod and rebuild the crank or ebay again. also i coat the cylinder and piston with WD40 when i'm putting it back together...
  15. #30
    May 2005
    Southern NH
    1,489
    Quote Originally Posted by ChrisD
    No another 6 months of wating isn't in my schedual Here's the wiseco page http://www.wiseco.com/PDFs/Catalogs/CB06/HondaATV.pdf This cylinder is on it's 2nd to last bore, so what do I get for a bore size??? I don't see anything that's close to 72mm, if that is what I need..... There all a few more CC's than stock (262cc max)...... So would i have to send this cylinder in to get a custom piston? That won't be cheap....
    The only brand label on the cylinder is on the left side of the intake, it's an HM with a circle around it. Anybody know this brand?
    I've been thinking, why can't I just cut the needed amount off the piston skirt like billy suggested???? The pistons look the same except for the half-moon cresent on the bottom. Can this be done?
