Results 1 to 9 of 9
Thread: 85 250es wont start
    robb is offline New to the board Arm chair racerNew to the board
    Sep 2006
    bc canada
    63
    85 250es wont start
    i got spark now and cleaned the carb put new spark plug in and it doesnt start. i dont have the battery if that matters. ive been kick starting it anything i should look at .
    NE Arkansas
    2,344
    Is the kill switch off? It's probably the simplest thing. When was the last time it was running? Check all the connections.
    Travis
    My Rags
    Sep 2006
    bc canada
    63
    kill switch isoff . i had it going for a few seconds yesterday but ive never had it going i just bought it cheap because there was no spark,
    just trying to figure it out the tank had rust i cleaned it all out cleaned the petcock thing then put gasss in even tryed closing the gap a little on the spark plug ?
    Howard's Avatar
    Howard is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Memphis, Tn
    288
    also the nuetral switch if sitting on the trike, the right side of the motor torwards the back there is a small metal cover that you can bend, two wires behind there make sure they are good and connected. if it doesnt see a neutral it won't start.
    1985 250ES ATC
    1985 200X ATC
    1984 250R ATC
    1983 LT-50
    1991 LT-80
    1996 YFB-250
    >->->->Hgoody77@yahoo.com
    NE Arkansas
    2,344
    He's right, does the neutral light try to light up when your kicking it? Even though you have it in neutral, that connection has to detect it, like Howard said.
    My Rags
    Aug 2006
    Carterville, Illinois
    271
    Also take *Edited**Edited* plug out and clean it off really good and w/ a wire brush, spray off w/ Carb Cleaner, dry. Then try grounding the plug on *Edited**Edited* head and kick start it, look for spark. It could just be fouled out.
    leroy, new york
    1,025
    sounds like fuel problem
    Sep 2006
    bc canada
    63
    thanks i found out it wasnt getting enough fuel so i cleaned the tank again and now theres fuel pouring out not drippin out but the chock cable is broken so i think thats the problem .i ordered it so i will know wednesday.
    Sep 2006
    bc canada
    63
    i didnt have the airbox .on now it runs awesome it fired up .honda tech said it needs that to run proper? but the oil drain plug fell out somewhere.
