Thread: 1983 honda 110 questions
    y2kane's Avatar
    y2kane is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Deshler Ohio
    291
    Question 1983 honda 110 questions
    For those of you who have seen my honda 90 questions, well it is a 110 like it has been so kindly pointed out to me. It was leaking oil out the back and from around the chain. I ran into a snag. I didn't have to proper pulley puller so I could get the outer case off. So being the person that I am and that I have access to a 3000 watt laser, and having some programing experiance I made one out of 1/4 950x steel. That one bent as soon as I started to put some torque on it. So I made one out of 1/2 inch 980x steel. That one worked like a charm. I took everything off and there by the sprocket was a dime size chunk taken out of the case. I found the chunk and filed it down so it would fit nice and snug in the hole. I put JB weld in the hole first placed the piece I filed down in it and slapped more JB weld over it and it is harding as I type.
    My questions are, When I go to put it all back together how tight is the chain supposed to be on a 1983 honda 110? There is a whole bunch of slack in it. I can lift it atleast 2 inches of the tension sproket. Should it be that loose. I am guessing not but I am not sure how tight it is supposed to be. I imagine this is the reason I had the chunk taken out of my case.
    My second question is when I took off the chain guard there was a 4 inch plastic piece floating around in there and I don't know where it goes. the Haynes book I have doesn't say anything about that and where it is supposed to go. It seems to fit on the bolt that the tension sprocket is on but I am not sure and if that is where it goes what is the purpose of it?
    Thanks guys. I will let you know how it all turns out when I do get it back together
    1982 Honda 185 My work horse
    1985 Honda 125 kids love it
    1984 Honda 200S My main ride
    triker111's Avatar
    triker111 is offline At The Back Of The Pack Arm chair racerFirst time rider
    miami
    162
    Im not sure about your second question.But as far as the chain slack goes i dont have the exact recomendations but usually about 3/4 to 1in of slack will be good not more than that. Also you need to buy a case saver this is a very good insurance policy. you can usually pick one up on ebay.
    savin one atc at a time
    illinois
    743
    chain buffer mabe?
    triker i want you lil trike lol
    nice
    y2kane's Avatar
    Deshler Ohio
    291
    It's alive!!!
    T he piece is fixed and everything back together. Rode it out to my mom and dad's about 3 miles to check it. Leaked a little oil around the sub transmission but I pulled that off again and put sealer around it. I am going to leave it harden over night and I will try it again.
