Thread: Plastic restore
    Oct 2005
    Vicksburg, MI
    73
    Plastic restore
    I just bought a used replacement gas tank and it is sun faded bad. Anything out there that would bring it back to red. If not is there a paint that would work good on plastic and not react to gas. I would rather not paint it unless it is only choose though. Thanks
    Pa.'s Highest City
    8,058
    Hi, chances are if you paint the tank without sealing the inside with creme or a similiar product (redkote) it will breath and the paint will bubble.
    You will find this thread helpful.
    http://www.3wheelerworldforums.com/s...lastic+restore
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    There are a couple of write-ups here on the forum on how to go about it.
    If it isn't too bad sometimes Armor-All, or vinyl protectant, and also a polish and wax can get rid of a lot of it for a while. If it's real bad, then you need to go further.
    What I did on my 250R tank was use light sandpaper to get the oxidized plastic down real close to all red, and went progressively finer.
    When it was close to a final finish, I used buffing compounds with a wheel, gradually going finer, till I got it buffed out to a nice glossy, scratch free finish.
    When you get all done, use a good wax on it, and wax it regularly to help maintain it.
    If you can, keep the trike indoors when you're not using it.
    The sun kills plastic, as we all know, so the less sun the better.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    Just wet sand it all alot with a fibe girt sandpaper, that what i did to my dirty stained fadded gunky plastics and they shine and look good now.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Jun 2006
    Illinois
    491
    Sand it out. Start with something like 400 grit and work your way to 2000 grit. Then rub it out with a fine-cut rubbing compound and finish up with Meguiars Scratch-x. Make sure you use a lot of water when you wet sand it and maybe a little bit of dawn dishsoap in it also. I'm sanding down my black fenders and rad scoops on my tri-z and it's turning out prety good. A lot of elbow grease though.
    Oct 2005
    Vicksburg, MI
    73
    OK sanding makes it look nice and shiney but it is still the same old orangey looking tank. I think the sun took the die out of the plastic or something. Almost looks the same on the inside. I think it is a differant type of plastic then fenders. Ive had good result sanding them.
