Results 1 to 3 of 3
Thread: yt125 problems
    Sep 2006
    kennesaw
    yt125 problems
    Hi, I just got my first trike, an 82 yt125, I do not much about trikes.
    How do you remove the clutch, I got the clutch cover off, I just dont see any screws or nuts on the big round clutch pack.
    The reason I am taking it off is because the auto clutch is stuck engaged.
    From what I have read there are two clutchs, I guess the auto clutch is indside the big round clutch pack, is this right?
    Also how hard is it to change the crankshaft seal on the clutch side?
    Thanks a lot
    Dustin
    Sep 2005
    Lipetsk, Russia
    2,824
    If you know how to shift on a manual transmission machine, you shouldn't need the centrifugal clutch, should you? You can use the shifter to "clutch it" with the disconnector clutch. I do it all the time on my dad's Rancher and my Big Bear.
    I'm back in the USSR...
    illinois
    743
    go to bike bandit - look up the clutch on the parts finder and figure it out .
    youll have the page in front of you, save it on your p.c
