yt125 problems
Hi, I just got my first trike, an 82 yt125, I do not much about trikes.
How do you remove the clutch, I got the clutch cover off, I just dont see any screws or nuts on the big round clutch pack.
The reason I am taking it off is because the auto clutch is stuck engaged.
From what I have read there are two clutchs, I guess the auto clutch is indside the big round clutch pack, is this right?
Also how hard is it to change the crankshaft seal on the clutch side?
Thanks a lot
Dustin
If you know how to shift on a manual transmission machine, you shouldn't need the centrifugal clutch, should you? You can use the shifter to "clutch it" with the disconnector clutch. I do it all the time on my dad's Rancher and my Big Bear.
I'm back in the USSR...
go to bike bandit - look up the clutch on the parts finder and figure it out .
youll have the page in front of you, save it on your p.c
//ArrowChat Integreation Code
