Results 1 to 3 of 3
Thread: 83' 250R Wheel Spacers??
    Feb 2005
    Canada
    663
    Does anyone know where I can get some? Also what do you think of them, do they make a big difference?
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1983 Yamaha Tri-Moto 175
    1983 Honda Big Red 200
    1981 Honda ATC 110
    Jan 2005
    Great Bend
    704
    well you can get some dura-blue wheel spacers. any spacer with a 4/110 bolt pattern will fit up to your hubs. you will then have to either get stud extentions that dura-blue sells or you can press out the original studs and run longer bolts.
    you might try and locate a set of hubs off of a 250X or 300EX quad. they run the same spline count and size as the 83-4R's and they are an extended style hub that will give about 3" of extra width total. and then if you get a hold of a set of high offset rims then you dont need spacers. the dura-blue spacers will only give you 5" of total extra width.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Anaheim, CA
    517
    i have the durablues on mine they work fine and make the trike a lot more stable, especially if you have flatter profile tires (holeshots, razrs etc) vs the balloon type. i run some old school cepek tires on my r with the spacers and its miles better than it was w/out the spacers and the "balloon" pro vector tires. the other option Atcwrench gave you i considered but the spacers cost less than the hubs and a set of rims.
    83 250R
    91 CR125R
