Thread: Please Help!! Running like crap
    Apr 2006
    Bronco Country
    64
    Hey guys. A few weeks ago I went out to ride the trike, and gas was leaking from the carb, and it ran like super crappily. It was really jerky and at high RPM's it didnt go fast at all, it just jerked a lot. So I took the carb apart today, and it was pretty clean and i didnt see any problems with it. So I put it back together, and it still runs like crap, if not worse than before. It idles fine, but when I give it gas it just is super choppy. Any ideas of what could be wrong? I have no idea what the problem is, and need help. Thanks everyone.
    Go Broncos!
    BTW, 1984 Honda 200M
    Columbia
    5,131
    Its clogged in there somewhere. Make sure your needle valve is moving freely, its probably sticking.
    That should be your problem.
    -Eric
    Apr 2006
    Bronco Country
    64
    So you absolutely definitely think its in the carb? I may do it once more, and this time run air through everything and use carb cleaner. Is there a possibility the floats are full of gas and are letting too much gas in? Thanks Eric.
    Go Broncos!
    illinois
    743
    does it leak out the overflow tube??
    needle and seat might be wore out
    pipe clogged up??
    timing advance rusty???
    Apr 2006
    Bronco Country
    64
    I'm not sure where it leaks from, I will have to check that out. Thanks.
    Go Broncos!
