Results 1 to 11 of 11
Thread: 200x
    Sep 2006
    California
    200x
    I have a 1984 Honda 200x. It has been sitting in the garage for over a year. I went ahead and changed the oil, air filter, spark plug, cleaned the carburetor, and cleaned the gas tank out. It wouldn't start for nothing, so I went ahead and push started it. It started up, but was set at one certain speed. Do I need to replace the twist throttle? I twist and nothing it continues to stay at the speed. Another thing, when I started to hit on the brakes to get it ready to stop it would start idling real loud. I went ahead and tried to kick start after all of that and nada. I checked the choke and it was good. The gas switch was on. Don't think I left any step out . Any help is appreciated.
    Levithan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Puget Sound, Washington
    319
    Check the throttle cable and slide, something may be either stuck, or disconnected. Have you checked the spark? It should be white or blue. Is there pressure when you kick the kickstarter? Let us know what happens!
    1984 200X Auto X
    1984 200X! Keep em riden!
    1984 Kawasaki Tecate 3.....
    More to come
    Sep 2006
    California
    Levithan thank your for your response. After posting the message I went ahead and checked on the throttle and noticed that the wire basically was hanging out. Ordering a new twist throttle. I'll keep you posted just in case there are any more problems. Again Thank you for your response.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Have you adjusted your valve lash lately?You could be looseing alot of compression if they are not adjusted properley.
    Sep 2006
    California
    Just received my twist throttle kit. I put it all together and I'm still coming with the same result. Like it is stuck. Do you think I should go ahead and replace the carb or get a carb kit? "edog" I have not adjusted valves. How would I go about doing this? Thanks for the help.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    First you get a manual then a feller gauge.
    Sep 2006
    California
    Had to hook the carb slide in wasn't going all the way down. Now it runs, but it still sounds like it is over revving while driving. When you hold the clutch in is when you really can hear the revving sound.
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Get a carb kit, that may solve it. They are around 15-20$ from Dennis Kirk (www.denniskirk.com) Let us know what you are going to do. Also, I would get a thumb throttle, I have had no luck with twist.
    TF 07,08,09,10,11,12,13,14!
    Jan 2005
    RI
    2,530
    could be the cable is routed incorrectly also.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Phoenix, AZ.
    6,719
    Quote Originally Posted by santanashonda
    Check for intake leaks. The boot the goes from the carb to the motor in particular. They crack sometimes. You can spray starter fluid around that area while it's running and listen to see if the idle changes at all. If it does it's sucking in air.
    leroy, new york
    1,025
    Quote Originally Posted by DeePa
    Had that problem before!
