Tri Z swing arm question
I have been searching for an extended swing arm for my tri z and havent had any luck what so ever. I heard that a banshee swing arm is the same except where the swing arm bolt goes through the case on the tri z.... I was told that you can simple cut the center out of the swing arm so it fits the case. is this true?.... has anyone tired it yet?.............and how far should i extended it?......
'85 Tri Z 310 Sprock big bore, cool head, shearer pipe, 40mmPWK, Vforce3, Zinger tank, +8 swing arm Lone star 2+2 axle and hubs.
86 BIG WHEEL 200
87 BiG Wheel 350
87 LT500R-- FTZ drag port, shearer pipe
07 M109R
