Results 1 to 8 of 8
Thread: Rad 350x Axle Nut Questions??
    Sep 2005
    Northwest Ohio(Forest)
    974
    The axel nut on mine is so rusted and old that it wont loosen up. I got it off and in a bench with a torch and pipe wrench and still cant get it. So will the rad axle nut work, or is the rad one only for the rad bearing carrier? Thanks!
    Sucks i have to pay 60 bucks for a frickin nut though!!!
    Anybody got one for cheaper???
    '86 200x
    Jun 2003
    englishtown NJ
    2,676
    I know the durablue one will work on all liquid 250r's and 350x's. The rad one should work on a stock carrier.
    Minnesota
    784
    How did you get it apart with out being able to loosen it? They are left handed threads, so make sure your going the right way. The larger nut is a jam nut and needs to be loosened first.
    Sep 2005
    974
    They were really loose kindof. And the axle slid to far to the left. I took the clip off and it slid off. lol. I need to tighten it now but the 2 nuts wont break loose.
    '86 200x
    Pete is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2003
    Lino Lakes, MN
    229
    problem is, the rad nut only comes with the nut, you still need the threaded sleeve.....
    Sep 2005
    974
    Ok, and what about the durablue antilock nut thing. Denniskirk and rockymountain carries them. They look like the whole deal right..but will durablue fit a stock axle, or only durablue axles?
    Link to durablue nut:
    http://www.rockymountainatv.com/prod...7&navType=type
    '86 200x
    Jun 2003
    englishtown NJ
    2,676
    I have a durablue one on my 85 atc250r, its a whole piece and includes a axle clip also. the instuctions say it fits on a liquid 250r and 350x.
    Sep 2005
    974
    Nevermind guys i got it with the stock nut.
    AWESOME!!!! Now my chain is perfectly aligned and tight, i have a 14 tooth up front....It helped finding out it was reverse threaded LOL
    '86 200x
