What the OD is on 350X Fork Tubes????
Thanks in advance,
Thanks in advance,
85' Tri-Z 250
85' Drag Tri-Z, BBBBBRRRRRAAAAAPPPP!!!
85' 350X
06 TRX90
78' ATC70 Project
03'250EX
87 Ninja750 3wheeler![]()
hey, ask your wife, she seems to "know everything"!![]()
same as a 83-84 250r 35mm... 8.0 in travel I do beleave some one correct me if im wrong.
Hmmmmmm,,,,,,Correct me if IM wrong....Isnt that the same as the 85 Z??? I know the 86Z is 39mm....What is the Same as the 86Z.....I need a set of 86Z forks for the Ninja...Nathan F'ed em up when he Shipped them to meOriginally Posted by bryan raffa
85' Tri-Z 250
85' 350X
06 TRX90
78' ATC70 Project
03'250EX
check 85-86 250r there bigger than the 350x I think they will work in the z tripple
YES they will work there 39mm 85-86 forks are the same as the 86 tri z but you will have to run a honda rim and brakes... witch is better because you have better choices for a front tire!!! and better stoping power!!!! duel piston vrs. a single.to slow that ninja down.
and there way easey to find! That also means that progressive fork springs will also work for the 85-86 r and the 86z
Not since your wife knows everything!!
1984 Honda TRX200
1985 Yamaha 200ERN ( two of these now)
1985 Honda 250SX
1991 Suzuki LT230
2003 Honda Rancher 350ES
WOW!!!! That is the First time Ive heard that one....Good JobOriginally Posted by mark38090
I wonder if the R and Z Triple Spacing is the Same???? Or if the Z Axle will work in the R Threads![]()
85' Tri-Z 250
85' 350X
06 TRX90
78' ATC70 Project
03'250EX
now that i dont know.. I was going to use the whole front end from a 250r for my drag bike,But i ended up finding a set at the last minute that was in good shape so i didnt get that far..Good luck
if ya find out keep me posted on that..for my future project..![]()
Well OKIE DOKIE then.......Thanks for your Help.....
Anyone Want to get some 250R Triple Measurements for me????
85' Tri-Z 250
85' 350X
06 TRX90
78' ATC70 Project
03'250EX
I'LL GET EM FER YA !!!
Hey ..... the threads on the front axels are the same 14x1.5 and the shaft is 15mm.... BUT................
the threads are longer on the ATC and the 20mm area by the 17mm hex is longer
a TRI-Z Rim,Hub and Spacer's fit right into the ATC Forks but you need to use the ATC Axel
we used to do that to the ATC's back in the day for the Grooved 12" Car Tire
"07" DR650 Suzuki Dual Sport
Hey Craig I got some nice R forks I changed out on my build up R. If you need some let me know and we can work a deal.
86-87 Tecate ROCK!
the tripples are the same width. 11 inches center to center on everything that had a skinny front tire.
