Results 1 to 15 of 25
Thread: ahhhh the grips in my hand but were is my bike
    yuma AZ
    22
    ok so my grips came off and almost killed me when i was going into a turn i have a new set and i want to know how to make the stick GOOD! any help?
    Kansas City, MO
    93
    Yes it will about kill you,,,,I've been there.. Make sure to use some good grip glue. It's cheaper than the doctor bill.
    yuma AZ
    22
    well glue didnt come with my grips ive heard you can use spray paint?
    any other household items i could use im poor
    spray some spray paint in the grips put them on and let it sit in the sun..primer works good thats all i do never has a problem
    Sep 2005
    Massachusetts
    1,272
    Ive also heard hair spray works.
    2000 Rm250
    1985 IT200
    2003 suzuki sv1000s
    2008 polaris outlaw 525s
    hair spray will work untill it gets wet!!! ask any girl!
    yuma AZ
    22
    thank you for the quick replies raffa and dgould i post a pic of my new handle bars with the grips on them later!
    Phoenix, AZ.
    6,719
    The compound of the grips you're using play a big part in how well they stick. Soft grips will twist even with glue. I've used grip glue, rubber cement, spray paint and a few other things. With a hard compound grip, spay paint or grip glue will work great. With a soft compound grip, I have yet to find anything that keeps them from twisting.
    I have an idea though. I just got some EVO grips that are a dual compound. Stiff underneath with a softer gel compound on the top so they SHOULD stick pretty well with a traditional method but I'm going to take it a step further because I HATE it when my grips move around while I'm riding. I'm going to get out the dremel with a cutting wheel and carve some small grooves in the handlebars. Both horizontal and vertical and jagged as possible. This should give the grips something to dig into and hopefully they will never move again. The tighter I'm holding on, the more firm the grip should be (in theory).
    bp739's Avatar
    bp739 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Southwest,Pa
    297
    WD-40 works well as an emergency grip glue....spray it inside the grip or on the bar and spin the grip around a few times, then let it dry,it will stick very well for quite a while, but once the grip gets wet you'll have to re-apply it.
    85' YAMAHA TRI-Z
    85'
    HONDA ATC 250R
    85' HONDA ATC 350X
    86' HONDA ATC 200X
    05' KAWASAKI KFX 700
    Apr 2006
    PA
    1,464
    I always use wire! wire them on nice and tight and there not moving.
    Lancaster, PA
    1,738
    spray paint , wire and back when I raced GNCC I would weld a nut inside the bar and use factory honda plastic bar ends that way IF the grip came loose it would not fall off, you can ride (race) with a loose grip but not so well with a muddy bare bare end.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Gorilla glue works good. Or wrap duct tape around the bars and then put the grips on.
    TF 07,08,09,10,11,12,13,14!
    Aug 2005
    Oregon
    490
    had the same problem....crested a dune, got a little air then i find that im only holding on with one grip. incedently i fell off the back breaking the flag w/ my rear-end. one thing i love about the sand...soft lands
    Sep 2005
    Saskatchewan(Moose Jaw)
    769
    I have never had this problem, but maybe Elmers spray glue would work. I have used it for my school assignments and it hold really good.
    Current Rides
    3 skidoo's, 1 quad, and 1 trike
    http://www.cardomain.com/ride/2679723
    Jun 2004
    Oregon
    1,784
    paint works good thats all ive ever used..
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
