Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: ahhhh the grips in my hand but were is my bike
    yuma AZ
    22
    ok so used some spray paint and one is on and good but the other keeps coming off and somewhere in the process of putting it on again it ripped rawwrrrrrr
    so i said the hell with it and put my old oem blue bad boys on with spray paint and they are sticking pretty good it feels like im gunna let it sit over night and see in the morning. good ollll honda
    im gunna wire them too.
    thx for all the help guys i really appreciated the quick help you provide!
    Jun 2006
    Ohio
    2,294
    We always use 3M spray trim adhesive. Sand the bars first, spray some on the bars, spray a little in the grips and slip the grips on. They never twist around.
    1981 ATC 70
    1978 ATC 90
    1985 ATC 250R
    www.cosmicquads.com
    Ontario, CANADA
    4,538
    Ive tried the paint, WD40.....
    Ive found only zipties/tie wraps or wire works. Put the zipties on, sand them down with a file so they arent sharp and wear gloves. I cant feel them one bit, and it keeps your hands on the grips during mud. People at TF06 can say how muddy it was lol, and im glad I had them!
    EDIT-
    this is how muddy it was.
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Pro Honda brand grip glue or 3MM "Yellow snot" weather strip adhesive.
    springville, PA
    6,185
    Quote Originally Posted by Kintore
    Absolutly. I've tried paint (never held), tried spray foam (held for about a week), tried moose grip brand glue (2 weeks), zip ties (worked awesome). Zip ties were the only way to get them to stay on at TF
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Northern CA
    1,104
    All you guys need is a little Gas....Pour some in the Grips...Let sit for about 20 Seconds pour out and Put on....Problem Solved....
    85' Tri-Z 250
    85' Drag Tri-Z, BBBBBRRRRRAAAAAPPPP!!!
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    87 Ninja750 3wheeler
    Aug 2006
    new hampshire
    914
    if your running a thumb throttle go to www.blowsion.com and buy a set of odi rouge 90mm with billet thug plugs and aluminum lock rings the whole set up will run you around $50 shipped. the besr grips period.........NONE FINER!!!!!!
    the wetter they get the more your hands grip the rubber! there soft and i have a set on my v fource and there over a year old showwing minimum wear.
    1982 ATC 70
    1983 ATC 200E yard rat
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2009 Brute Force 750
    2020 CF Moto 600
    Maine
    466
    I've used rubbing alcohol, pour in the grip and slosh it around for about 15 sec, shove it on to the handlebars andmake sure you get it on all the way within a second or two when you start sliding it on or they will stick when half way on. this has always worked for me.
    troy's Avatar
    troy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2006
    Canada
    254
    LOL...i replaced mine with hand warmers. Problem was the damn battery charger can't keep up with them. it kills my battery.
    Aug 2005
    Oregon
    490
    oh...i forgot to say, i bought a pair of scott grips (very nice if your looking for some) then the scott grip glue stuff also and its working great so far. been out a couple times and they are still on there nice and tight.
