Results 1 to 13 of 13
Thread: 350x rebuild questions
    Hampton, Virginia, C.S.A.
    2,664
    well it looks as though it is about time for a rebuild on my 85 350x....its burning a little oil and smokes when first started or hard trottle....i think im gonna ride it thrue the winter in the snow and rebuild it here in a few months....i just want to know what to acpect money wise so i can start saving ....my questions are.... how hard is it to rebuild the motor still in the frame....or is it even possible....also what would be my best and cheapest way to get a top end gasket kit....i already have valve stem seals and rings...i just need the gaskets and i heard one is discontinued...if any one has any info it would be a great help.
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Dads is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2002
    Richmond, NH
    219
    burning oil when you first start it is valve guide seals, Maybe bad guides.
    You have to pull the motor.
    you can get a complete gasket set off e-bay
    2,664
    well when it warms up it stops....but under hard trottle it smokes....i have notice its kicking over a bit easier so its loosing some compression...but it still runs great
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    2,664
    by the way any suggestions on not breaking motor mount bolts...i see this all the time ive even see the case crack trying to get the rear motor mount bolt out
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    PA
    3,515
    never had a problem with motor mount bolts or the case
    sounds like you just need a simple top end job and it will run at least $200.....good luck
    WWW.HREATV.COM
    2,664
    well i already have everything i need other then a gasket kit and maybe a piston ...so i think if i dont need a piston im probly looking at about$100
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Dec 2002
    Richmond, NH
    219
    You will find you have to bore it. If you just put in new rings they will not last long.
    2,664
    bore it? i thought all you needed to do was hone the cylinder inless it was in bad shape
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    illinois
    743
    its old and probably wore out
    at least bore it to the next size ,and use a wiseco piston kit, have the head surfaced , and guides checked replace as needed ,atleast (lapp) the valves,or have a valve job done
    hows the crank?,
    oil filter?
    clutch basket ok?-- any grooves wore in it ,if so file them down smooth again and it will be ok
    you have a choice on the piston- 10:25:1 -- or 12:1 i would go 12 if i could
    dennis kirk has the kits
    timing chain-?/ tensioner,and guide???
    top end gasket kit is-28.99
    a complete gasket kit from vesrah is 70.99
    you going to put in a new cam while you at it ??- i got mine from web cam ,but got screwed on the core charge!!
    so i need one for a 200 x now
    do every thing you want this time and youll be happier than if you didnt
    2,664
    Quote Originally Posted by jason 32
    hows the crank?,
    oil filter?
    all that would be nice if money wasint an issue here....but money is a major issue here....i just want to leave everything stock everything i do with this is gonna have to be the cheapest way possiable...im a poor college student and in the middle of doing a major overhaul on my trucks rear end.....my plan was to pull it apart hone the cylinder..lapp the valves replace the rings and valve stem seals and put fresh gaskets in it.
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Fresno Ca
    2,695
    You dont NEED to pull the engine to do the top end. But i do higly recomend it because you will have to drop it in the frame (diffrence is you can leave chain and electrical on) For fast rebuilds thats the way to do it but its much better to take the engien out.
    Also there is no need to bore it unless the cylinder is scared bad. Piston and rings should be changed and cylinder honed. Smoke on startup and under thorttle would meen you need a piston, not valveguides/seals
    If you have any questions feel free to pm me, i rebuild these babies very often. Soemtimes even do it for the fun of it.
    kb200x's Avatar
    kb200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    KY
    295
    Quote Originally Posted by threewheelin-feelin
    I just did this before Trikefest. I got new oem rings cleaned up all the carbon off the piston and head, lapped the valves added new seals and a light hone on the cylinder and a gasket set. It would have been nice to replace everything but its not reqiured. Listen to NOS. I was asking the same questions as you when I was doing this.
    86 350x "O' Smokey"
    83 200 auto X
    84 200x
    85 110
    82 70
    illinois
    743
    well you need to check the piston to cylinder for clearance
    before and after honeing it you dont want to put it together if its past the ware limit-thats why i said to bore it,plus its???21 years old?? it could probably use it
    and i know what its like to be poor-lol ,because i am!!
    but its better to do all right the first time, but theres always room for error,so take your time
    and since it is apart i was suggesting that you check the rod for ware,it doesnt matter how much money you have /or dont have when it comes to checking the parts---
