Results 1 to 3 of 3
Thread: WHat forks and shock will fit an 82 250r,I would like to upgrade.
    dufrain's Avatar
    dufrain is offline At The Back Of The Pack Arm chair racerFirst time rider
    KY
    239
    Arrow WHat forks and shock will fit an 82 250r,I would like to upgrade.
    Im looking to upgrade the forks and shock on the 82 250r.Will 85 or 86 250r forks fit without major work.I have read on here 200x forks will bolt on I was wondering if the 250r ones will to.My shock is bad and I would like to know If any others will bolt in there to upgrade it .Thanx
    85-70,79-110,79-110,80-110,86-250ES,85 250r,86 350x,82 250r
    May 2008
    Juneau
    605
    200x front end is a direct swap with no fab required
    3 wheelaholic
    ATC200/CR480 custom
    1984 atc250r near mint
    wr450f trike on the way
    Trizinger for my sons
    Surprise, AZ
    2,428
    Keep in mind you must use the 200X triple clamps, the forks won't fit otherwise.
