Oil Leak From CLutch Adjuster?
The ATC 70 I just got has a pretty fair oil leak from the auto clutch adjustment screw on the RH side of the motor. It seems to be seeping out from under the 14mm nut that is used to lock the adjustment screw in place. I see there is a small O-ring in there from the pic I found on bikebandit but I was wondering if anyone has had a similar problem with their 70/90/110? I got an O-ring that seems to be the same size (8mm x 1.72mm) but I figured if someone here has had this happen before they may have some insight for me. BTW that little sucker is almost as much fun in my yard as my 330R is on the frozen lake.
John
1985 Eddie Sanders ATC330r
1986 Monstecate
1984 ATC70 (awaiting 125cc transplant)
1984 ATC125M
1986 GSXR 750 - Keepin' it old school!
1999 Arctic Cat 500 4x4 plow machine
1999 Arctic Cat Thundercat 1000 (lake lizard)
1996 Arctic Cat Jag 440 L/C (ditch banger)
