Results 1 to 15 of 16
Thread: 200x wiseco issues.... Pics added
    Jan 2004
    8
    I overhauled a buddys 200x. I went with a wiseco .20 over 11:1 piston. Well I got it back together started it up and went out to test ride it. Well I kept hearing what I thought was the valves. Something just wasnt sounding right so I took the motor back out and took the head and cylinder off. I was looking at the cylinder, which looked fine, then inspected the piston and noticed the around the intake it looks like the piston is hitting the head. Not like ing it but deffinately hitting it. What are my options at this point all? Thanks in advance.
    Aug 2004
    Ab Canada
    4,368
    wong year piston For that perticular 200x motor,,,,,or the B.E rod beaings is completly fubard'
    1985 Tri-Z-
    Aug 2006
    Arlington, Wa
    1,027
    I've heard of a few wiseco's being that way lately.... find a machine shop to relief cut the piston.
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    85' YTM 225DX (sweetie)
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    Jan 2004
    8
    No its the right piston and the rod bearings are in great shape. So i guess I need to go to the machine shop. Thanks guys.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Pics??????????????
    Nov 2002
    Kirkville, NY
    3,831
    Is the piston pointing the right way? I think the arrow is suposed to point forward.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jan 2004
    8
    Yeah it was in right. I will get pics this afternoon.
    hoser's Avatar
    hoser is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2005
    ILLINOIS
    284
    Why are you correcting wisecos machining errors, how about calling them and letting them fix it then at least they know they have a problem and dont keep shipping their problems out to customers.
    Jan 2004
    8
    Aug 2004
    Ab Canada
    4,368
    Kinda looks like the head was Cut down quite a bit.......Might be the problem.
    1985 Tri-Z-
    hoser's Avatar
    Nov 2005
    ILLINOIS
    284
    Why would the head be cut down?
    My concern now would be how much the rod bearings were ed and how long they will last, how much were the head bolts stretched as it tried to lift the head off the cylinder you can see where the head gasket was leaking....
    May 2003
    Shediac, New Brunswick
    1,126
    same thing happened to me, I used an 86-87 piston in my 84 though, but it appeared as if it were going to work.... I have the whole engine torn down and have for like a year.. I am going to try that piston again.. eventually.
    '84 Honda 200x
    slow restro
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by hoser
    I dont know but it looks like it has been, theres virtually no lip between the sealing surface and the Gasket area,
    1985 Tri-Z-
    illinois
    743
    mabe the head was milled down??
    have the piston milled a little
    -check the timing
    use a dremel remove some material
    -did it bend the valves?
    Jan 2004
    8
    Nope valves didnt hit. I am going to talk to a machinest about it tomorow and see if he can clean up the piston for me.
