Results 1 to 15 of 19
Thread: Tri-Z help ASAP
    Dusty's Avatar
    Dusty is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2005
    Groveport,Ohio
    435
    Tri-Z help ASAP
    ok ineed to know the part number on the kicker side side case for an 85 tri-z.......i have to order one tommorow morning so i will need it very fast i thank you....
    Dusty
    My Trikes
    1985 ATC 250r (MX Project)
    1985 ATC 70 (with pit bike motor)
    1983 ATC 110
    1984 225dx
    2005 SDG 110 Pit Bike
    OTC Tride & True
    Past Trikes
    1985 ATC 70
    1984 200s Almost Mint(stolen in 99)have pics of her..
    1983 YTM 200
    one minute
    38w-15431-00-00 crankcase 3 It's probley going to be a little over $100
    Watertown, New York 13601
    3,382
    Quote Originally Posted by bryan raffa
    I paid $108 for mine from the stealer.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    yep i payed $109 for the last one.... lol
    Dusty's Avatar
    Sep 2005
    Groveport,Ohio
    435
    thanks guys ........
    My Trikes
    1983 ATC 110
    1984 225dx
    OTC Tride & True
    Past Trikes
    1985 ATC 70
    1983 YTM 200
    Phoenix, AZ.
    6,719
    What causes these things to break so often?
    Jun 2006
    Illinois
    491
    I just think it's a bad design and there's too much stress where the reverse kickstart gear is. I am very careful when I kick mine now. Also, when the Tri-z came out, Yamaha never really had any time to work out the bugs from the 85 and 86 years. Maybe they would have fixed the problem in 87 if 3-wheelers weren't banned.
    ive found that if your bolts are loose or your missing some in the kickstart area they WILL break!
    na
    5,702
    when you kick the tri-z,it is always best to rotate the kicker down about 3 inches.if you try to kick the crap out of it from the top of the stroke,i think it puts too much pressure,on the side case.i have snapped a few kickers already,but no case.but mine was welded up real well and i think it made it stronger.also if the kicker gears are worn and letting the kicker shaft go cock-eyed,that can cuase them to break the side cover too.i say,dont kick the livin crap out of them and you will be fine.
    Proudly NOT a member of
    "Team on the Teat"
    now if we could do something about the kickstart levers from breakin on high compression motors that would be a plus!
    na
    5,702
    trx 250x kicker.way way stronger than any z kicker
    "Team on the Teat"
    Phoenix, AZ.
    6,719
    Does it bolt right on?
    yes but it needs a little grinding to miss the case
    Mar 2004
    North Central Ohio!!
    2,712
    Quote Originally Posted by moshman355
    I think I agree that the welded cases are stronger. After mine broke, we welded it up and it never failed again.
    Another thing I did to combat breaking one was to ziptie a small piece of rubber hose to the footpeg. When you kick those things a full stroke the kicker smacks the pegs sending some nasty harmonics up the kicker. This trick completely eliminates that.
