Results 1 to 7 of 7
Thread: What should I use to fix a small fender crack??
    Jun 2006
    Cushing,Mn
    538
    Hey guys,will Epoxy be OK for a small crack,no missing chunks or anything like that?
    It is only about 2 inches long and it's where the fender bolt meet the fork,should I use something else?
    Thanks for the info!!!!
    mark38090's Avatar
    mark38090 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Hawthorne, Florida
    354
    I saw on here somewhere that a heavy test fishing line worked well, so I drilled mine about every 5mm or so and threaded 50 pound test through it, then I took 5 minute epoxy and worked that into the weave. After it dried I sanded it smooth and painted. It's still holding up 6 months later.
    1984 Honda TRX200
    1985 Yamaha 200ERN ( two of these now)
    1985 Honda 250SX
    1991 Suzuki LT230
    2003 Honda Rancher 350ES
    Jan 2005
    Orange County, CA
    119
    "Shoe Goo" original formula.
    1985 ATC 250R
    1986 ATC 200X
    1986 TRX 250R
    St Helens, OR
    611
    Quote Originally Posted by Ryah
    yes
    also walmart has some stuff called "amazing goop" or something. works really well too
    Feb 2006
    EC
    1,607
    Quote Originally Posted by mark38090
    So the epoxy permeates the actual crack & w/ the stitching holding it together creates a bond that's THAT good, eh? I'm going to try that. Thanks! TGG...................
    Baltimore---Charm City, or Harm City? Ask Pat.....
    Aug 2006
    new hampshire
    914
    drill a small hole at the end of the crack to keep it from spreading.
    1982 ATC 70
    1983 ATC 200E yard rat
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2009 Brute Force 750
    2020 CF Moto 600
    Jun 2006
    Cushing,Mn
    538
    Thanks for all the info guys!!!!!
