Results 1 to 10 of 10
Thread: briggs 5HP engine mods?
    Jun 2002
    Mississippi
    2,552
    anyone ever done any? i have one that i think it would be fun to play with. i was thinking about shaving the head, some bigger valves, port work on the intake and exhaust, cutom pipe, and a 200x carb. i wonder what it would do on alcohol? i could lighten the flywheel and maybe even knife egde the crank.
    jsut looking for ideas for a crazy go cart.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Ashland City, TN
    2,576
    Here's a crazy idea for a crazy gocart. Put a small block Chevy on the back of that motha
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Feb 2003
    California
    623
    kart
    I cut the pipe on my go kart. Its a 3hp briggs. Its loud twisted
    Detroit, MI
    837
    LOL, anything you can think up. I don't think there's areally anything aftermarket you can buy, so whatever you can find that works is what you can do. I would go with overhead valve if It's avaliable, then when you shave the head down you increade lift and compresion at the same time. Porting would be easy also. The problems with flat heads is that they start to detonate at high RPM's, running tempatures, and other small stupid stuff causes them to detonate.
    1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
    Feb 2003
    Delano, CA
    616
    You can check Jeg's catalog. Look under the Jr. Dragster section.
    1979 Honda 110 ATC, CEET gas tank cover, 25X11X9 rear tires
    1984 Honda 110 ATC, orignal blue plastics,
    1982 Yamaha 175 TRI-MOTO, 26MM Mikuni
    Honda US90 ATC, Collecting Dust
    2004 TRX450R
    Feb 2003
    California
    623
    governed
    take the governor off if it has one, it will go a lot faster. twisted
    SE Minnesota
    533
    5 HP Briggs
    The junior dragsters run those on alcohol, and get 25HP !!!! (so they say). Heres one from jegs. You can get all the parts there too.
    http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1708&prmenbr=361
    83 YT 175
    85 ALT 125
    cmracer15 is offline At The Back Of The Pack Arm chair racerFirst time rider
    briggns 5hp
    there is TONS of after market for them. I race gokarts and that is the only block we can use. we run them on alcohol. in the class that i run (Stock lite).. we are alowed to do cams,raptor 3 pistin/rod..and we have specs on how far we can Mil the head and other things. I have a couple headers ill sale. both are trumpet pipes. they give the engine torqe around 5,200-6,300. i have an engine builder out of north carolina build mine..but i just built one myself in the garage...and put it on a little yard kart frame and man will it spin the wheels... I just signed a contract with yamaha...im going to be running there new 2 stroke kart engine they came out with in the 2 cycle class up in daytona Fl. for the nationals this year...i just got it last week and took it out for a test run..and lemme tell ya that is one bad ass gokart engine. If you realy want a ride go on yamahs website and get ya one of them. I have the Yamah KT100. I just signed with them for this year and see how i like it..the cool thing is i get it replaced/rebuilt for free...( now lets see if i can talk them into sendin me a banshee..)lol..lemme know if ya need any parts...ill see what i got. Or i can get them..probly alot cheaper then jegs.
    Chris
    3 racing gokart's
    02 Kawasaki ultra 150 jetski
    02 kawasaki 1100 DI jetski
    FullBore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    the problem with a Briggs engine, is they are low stress, meaning if you run them at over 4,000 rpm for a while there is a high chance it will break in horrible ways such as throw its rod or bend a valve on the OHV ones, they're generally ok when revved under load, you can leave the governor on, just bend the rod so you get around 4,000 out of them, if not, put a proper carb on them, like a mikuni, say 20mm, and a better silencer, you get less power with a straight pipe out of a briggs, they like to have a bit of back pressure, especially for starting.
    Nat
    1979 Suzuki TS100
    1984 ATC70, Broke
    1984 ATC110, Repainted and Rebored.
    1990 Suzuki SJ410
    Unsuspended Antics.
    briggs
    fullbore..your right on one thing..i do have to have them rebuilt about every 7-8 races. but i also run them wide open at around 6500 the whole time. but a short strait pipe will not make youe engine weake. I run them on short tracks because they give the engine MORE power at lower rpm. a short track, the engine does not wind up to 6500 till the end of the strait ..therefore i need more torque at lower rpm to pull me off the corner. my strait headers are about a foot long. now for longer tracks..i use bugal pipes. (Looped like a trumpet)..because they will give you more torque at higher "sustained" rpms...
    3 racing gokart's
