my gf's blaster has kinda taken a downhill (Edited due to authors inability to be considerate for young readers!). about 3 days ago it just started running (Edited due to authors inability to follow the rules!), kinda will idle but will die if you give it any gas.
now it'll run and run pretty decent for about 30 seconds when its BONE COLD. like in the morning. during the 30 seconds it'll slowly get worse and worse and bog down then die, then not run after that. sometimes it'll start and die quickly.
it has good gas, it is getting some spark (may be weak).
idont know what to do. i took the entire carb apart and cleaned everything. jet, bowl, everything. checked the reeds they seemed fine.
dont know what to do, except start replacing stuff. motor runs and sounds perfect when it runs for the 30 seconds cold. so i dont think the piston could be (Edited due to authors inability to use common sense!)
thanks in advance for the advice
btw this just happend one morning, didn't start acting up while riding or anything
