Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: Radiator water coming out of exhaust
    Nov 2005
    florida
    18
    a couple days ago i bought a 86' atc 250r. i was pull starting it and it was trying to run but it just wouldnt do it. i notice water on the exhaust so i stood it on end and water poured out of the exhaust. anyone kno what could cause this? maybe a radiator hose hooked up wrong?---DJ
    florida
    2,328
    95% sure BLOWN HEAD GASKET!!!
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    Little more info?
    Did it run when you bought it, or has it been sitting outside for ages?
    Water can come from a lot of places. Coolant only comes from one source.
    If it is indeed coolant, you have a blown head gasket. If it is only water, it may have come in through an open airbox lid, or something of the sort. They may have used straight water in the cooling system, in which case it would likely be a blown head gasket. If they did do that, maybe they knew it was bad, and just ran it with water. I have seen worse things done. If you have a little more info, it will help out.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    Nov 2005
    florida
    18
    the guy i bought it from just put a head gasket on it. he put all new gaskets in the top end. i'll change it and see what happens. it didnt run. he said he rebuilt the top end and all that was left to do was hook up the radiator hoses. i hooked them up and tried to start it and got nothin but water drainin from the exhaust.
    PA
    3,515
    head might be worped....check it with a straight edge
    WWW.HREATV.COM
    Phoenix, AZ.
    6,719
    When you replace the gasket make sure you re-torque the head bolts after a good heat cycle.
    Nov 2005
    florida
    18
    10-4 thanks.
    hoser's Avatar
    hoser is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2005
    ILLINOIS
    284
    Quote Originally Posted by freeze_sucka
    Dont just change the gasket to see what happens first look to see if that is in fact where the coolant is leaking, has the engine been ported perhaps they cut it thin and a bad spot in the casting has let loose, perhaps it is just a casting flaw that gave way, if it was in fact the head gasket then why did it leak they dont just leak for no reason, wrong torque applied? the gasket surfaces are FLAT and smooth some MORON didnt use a power gasket scraper or one of them 3M pads on power tool, 99.9999% of the time when POWER TOOLS are used to clean gasket surfaces they damage them, another thing to look at is the fastners are they the correct fastners, I just discoverd the 'bling homo' that use to own my TRX used chrome homo lug nuts on the cylinder, they dug into the cylinder surface and removed metal, they never maintained torque, looked bling bling but didnt work, if you see any 'bling' fastners I would look closely at what they really are and are doing.
    Here is a example of a casting flaw dumping coolant into the engine
    Here is the casting flaw
    Here is the chrome homo nuts some *Edited**Edited**Edited**Edited**Edited**Edited**E dited* used as cylinder nuts
    Here is the damage the bling did
    Here is the other side it damaged
    Like my back woods hick buddy says "Sure looks perty setting their"
    Take your time, until you prove different conside everything the guy that owned it before you did was done wrong, play detective, do a proper CSI, need some examples more are here http://12.215.122.222/CSI.htm
    Phoenix, AZ.
    6,719
    Quote Originally Posted by hoser
    This is about the best advice you're gonna get. That's usually first order of business when buying a used trike for me. I don't trust them until I open them up and have a look around.
    Edit: not sure if I should take exception to the bling homo remark. I do love my bling.
    Newfoundland
    5,280
    Could also be the water pump seal right? A similar failure killed my cylinder 2 weeks ago. Pulled the jug only to find a crankcase full of freeze.
    hoser's Avatar
    Nov 2005
    ILLINOIS
    284
    Quote Originally Posted by BigGreenMachine
    NO, if the punp seal was leaking it would leak into the trans and balancer area not into the crank cases, I guess if your crank seal was leaking it coudl happen but I doubt it, drain your trans, no coolant then thats not the route its taking....
    The "bling homo remark" was to hopefully bring attention to others that they need to be looking at the important maintenance items at the same time they are pimping their machines if they want them to be reliable as well as good looking....
    Phoenix, AZ.
    6,719
    Speaking of bling homos, here's three of them now!
    Newfoundland
    5,280
    Gotcha, no the tranny fluid is fine I checked.
    Las Vegas, NV.
    2,492
    Quote Originally Posted by Dammit!
    !, which one of those guys is you?
    Phoenix, AZ.
    6,719
    Quote Originally Posted by Red Rider
    I took the picture.
