Results 1 to 3 of 3
Thread: Front axle problem....85-86 R
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    I did my caliper conversion today, and things were good. I had a problem with my front axle/hub though. My old one (86 R) needed new bearings, and was absolutely not coming out.
    I purchased an 85-86 350X hub/axle complete with spacers (which I needed too).
    Problem is....the hub is locating too close to the fork, not allowing me to get the caliper bracket on.
    It is off by 3/16 to 1/4 inch. If I back the axle out some, all is well, except that the hub has freeplay.
    Are the spacers on the 350X axle different then the 250R spacers? That is the only thing I can think of.
    The axle is fine, and I think the hub is as well. I have a headscratcher here.
    Any ideas?
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    Dec 2002
    Orange County, NY
    1,772
    I think the difference might be in the location of the rotor on the hub itself. I remember running into a similar problem when trying to run the stock 350X front hub/rotor on my 350X that has a 250r fork set up on it. It had me puzzled for a while and I ended up going back to the 250r front hub I think.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC125M
    InPiEcEs's Avatar
    Apr 2004
    Northeast Wisconsin
    378
    Yea, could be. It's kinda strange. See, I had the axle threaded in, but not all the way. Just kinda threw it together to mock-up. When I tightened up the axle, I couldn't get my caliper bracket on, Not enough room between the rotor and the fork leg. So I grabbed my old hub that won't let go of it's axle. All was good. I couldn't really tell any difference in the two assemblies, but I never did look at the rotor flange.
    Unless the spacers are different, that must be the problem.
    1995 CBR600F3
