Results 1 to 3 of 3
Thread: will a trx250r engine fit in an 85 atc250r?
    Jan 2005
    Jones, Michigan
    1,821
    Well my engine needs the case welded around the shifter (or just replaced) so im looking on ebay for another engine/case. I know that the 87 and on trx engines were long rod engines but will they fit in my 85 atc250r? Will an 86 trx engine fit?? what engines will and wont work? I just finally got this liquid cooled R so im starting out not knowing much about them.
    Kevin
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    Any 250R engine 1985-1989 will bolt into an 85-86 ATC. They are all physically the same. The only issues you will have interchanging stuff is jugs/cranks. The way to get around that is.........if you have a short-rod crank, use a short-rod piston.
    If you have a long-rod crank, use a long-rod piston.
    If you use a long-rod crank, and a short-rod piston, you will need a spacer plate. They moved the piston pin to accomodate the longer rod.
    If you use a short-rod piston on a long-rod crank, the piston will be a few mm to high, because the pin is lower.
    Jugs are all interchangeable, with 88-89? having bridged intakes, which helps against piston skirt cracking a little better.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    Aug 2006
    Eugene, Oregon
    82
    yeah the 88-89 jugs are the same also.
