Results 1 to 15 of 65
Thread: What makes 200x kick starters slip? Several soloutions inside!
    Nov 2002
    Kirkville, NY
    3,831
    Seeing as I have my 200x low end apart, what is it that makes the kicker slip? Do I replace the spring that is on the kicker shaft? Other then buying a repair kit that is no longer available what should I do?
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Pa.'s Highest City
    8,058
    This probably doesn't answer your question but I think it is some useful info that Howdy poted a while back
    http://www.3wheelerworldforums.com/s...0x+kickstarter
    Columbia
    5,131
    Might just be your kick clip. Thats the clip that helps put the gears together. Check out a diagram for your kicker, and make sure everything is there, and functional.
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    For me the actual gears had broken teeth on them. Check out my thread.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    Nov 2002
    Kirkville, NY
    3,831
    The engine is apart now and everything looks ok but I bought the motor in pieces so i don't know if it was slipping before or not. I just figure that since I have it apart now I might as well do some preventative parts replacement.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Howdy's Avatar
    Celina, Ohio
    10,079
    The ratchet is the thing that mainly causes kick starter slippage. What happened is Honda put too weak of a spring ( the one that pushes the ratchet & gear together ). The allows the ratchet the wear off the tips of the teeth on the ratchet and gear. Once wore they are junk and will allow slippage.
    I know of one person ( it wasn't me ) who back cut the teeth on the gear and ratchet. I can tell you that it worked good, but it's not something the average person could do. I am going to do a set or 2 of these up for my own useage. But I haven't got my tooling set up yet. I can't do that until I get my garage finished. My home garage is going to be my machine shop.
    Also on the 1984 motors they actually had a weak starter gear that broke enough that Honda did a service recall on. It's the idler that mates up to the ratchet gear. The 1984 repair kits contained: 1 ratchet, 1 ratchet gear, 1 idler gear, and 1 spring ( it's stronger ). I should still have 1 1984 kit in stock. If memory serves me correct the 1984 kits cost me around $90-$100. I sold 2 1984 kits on Ebay for $150 or so each ( I was very Happy ).
    theFox: I will sell you my last 1984 Kit for $95 shipped. Other wise it will hit ebay some time in the future.
    Howdy
    Nov 2002
    Kirkville, NY
    3,831
    I will pass on the kicker kit Howdy but thanks for offering it, right now the trike fund is kind of low. I was hoping that there was a replacment spring, I think my gears look good so I guess the spring is ok but it would suck to put it all together just to have it slip.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by thefox
    I totally understand!! Have you checked to see if your kickstarter assembly was serviced by a Honda dealer? If not, then look down by the serial number. If you find a "X" stamped in the area then most likely they have serviced it already. If there isn't a "X" then it probably hasn't been upgraded. If you need / want just a updated spring, I have some of those as well. I will have to look up my cost on those. I think they are under $4-5.
    Howdy
    Nov 2002
    Kirkville, NY
    3,831
    I would check the case but I don't have it. I bought a shifter shaft and this kicker assembly came with it, the kicker assembly that came with my case is in the case 350 miles away and I didn't think of checking its condition before I left home. So I will buy that spring just in case. I will PM you.
    Thanks for the help!
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    so I can get away with ordering the stiffer spring? how do I tell the diffrance between the two....
    Nov 2002
    Kirkville, NY
    3,831
    The stiffer spring is harder to compress...
    The two NOS stiffer springs I have seen had a red line painted on them.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    so it looks like Im SOL..look the same to me..
    Attached Thumbnails Attached Thumbnails 2008_0316stuff0023.JPG   2008_0316stuff0024.JPG   2008_0316stuff0026.JPG
    Thats the kicker return spring (torsion spring) isn't there another spring that works on the splines and gets the ratchet gears meshing??
    See the bitty spring behind the smaller ratchet gear, I believe that is the problem spring. I imagine guys try shimming it??
    Nov 2002
    Kirkville, NY
    3,831
    The stiffer spring replaces the smaller one on the left end of the first picture. I found some part #'s (can someone verify these?)......
    200x starter kits
    1983, 06280-965-000
    1984, 06281-965-000
    1985, 06282-965-680
    Spring only, 28253-965-010
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    would shiming it work?
