Results 1 to 9 of 9
Thread: 200e resto coming along!
    Nov 2002
    1,189
    i got a 200e from my dad, not running, yellow, 83, for free, and i thought i might as well rebuild it to have another trike to ride on, or to have a powerhorse trike. i got it a couple weeks ago, and started tearing it apart. well, first thing, i go and try to take the engine out of the frame. well, then i see that the whole rear end had to come out! grr! so a day later, i get the engine out, and take the head and cylinder out. well lookee what i found! rust pits in the cylinder. i find out that the trike had been sitting under the eve of my dad's house for 2 years, when it died. so i put the engine aside until i can find all the parts, and get a little more dough. then i remember that the front fork seals were shot, and leaking oil. so i take the triple tee and forks off the frame. then i take the boots off and see that the seals are covered with rust. i wd-40 and carb clean it all off, then take the retainers out. to get the forks apart, i had to put them in a vice and use a sledge because the seals had swollen. a week later, my seals come in. i get the oil, and fill my shocks up. one q, are the seals supposed to be VERY tight? i had to use 2 pipes to pound those suckers down! i dont think that they are coming loose. when i am about to put the front end on, i am going to grease the bearings, but there is no zerk! to get that darn bolt out, i used a mual, and a lot of pounding. i found that all the metal pieces in the axel had rusted together. i said forget it, and i greased up the bearings, and slapped it all together after fixing the brakes up good.when i had the raer end off, i thought i would look at the rear brake. well, all the screws were so darn tight that i had to use some vice grips, and almost destroy the screw. the brakes were frozen solid, the rotor was stuck, and the pads were a nightmare. with some wd-40, i got it all apart, and use some steel wool to clean it up good. i got it all back together in the same night, and look for my next thing to fix....the foot brake. it was also frozen solid. i started pounding on it, then it broke off. i se that it had already been rewelded from previous rollovers and crashes. still tho, i have to fix the handle bars which are kinked. when trying to fix the curly brake handles, the rear one snapped...grr. so far, i have bought fork seals, fork oil... and thats it in a couple days, i will buy a manual :-D , oil filters, fuel filters, gasket set, piston and rings, and a few other things. i will keep you all updated daily, and post some pics once i get a digi cam to use. i hope all of the other restorations go easier than mine! haha
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Nov 2002
    1,189
    i bought a spark plug! haha, i will get some pics up very soon, hopefully tonite.
    My Rides
    Yamaha 200E
    Minnesota
    790
    Good Luck fixing it up. :-D Someone painted it yellow? Honda Big Red 200E right?
    -86 Polaris Scrambler 250r/es - sold
    -84 200es Big Red
    -92 Ski-Doo Formula Plus 583 -88 Safari 377 -68 Super Olimpique 299
    -87 Jeep XJ 5" lift/many other mods-sold
    -89 F-150 4" Lift/33s
    -90 Acura Integra - '83 Mustang 5.0 convertible (the new project)
    Ask me about custom cut decals!
    Nov 2002
    1,189
    nope, its a yammie
    My Rides
    Yamaha 200E
    Mar 2003
    Barnesville,Ohio
    2,298
    WTF?? Honda made the 200E. Yamaha made Tri-Zs.
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Nov 2002
    1,189
    no, its a yammie, it is called a ytm 200 e-shaft, for electric start and shaft drive, and 200cc's
    My Rides
    Yamaha 200E
    Minnesota
    790
    200EL mabye? (I know Yamaha made those...)
    -84 200es Big Red
    Minnesota
    790
    http://www.3wheelerworld.com/1983yamahaspecpage.shtml
    The only trikes the site has for 1983 that are 200s are K and KE :?:
    Yeah, I'm sure you would know if its a Yami though :-D
    -84 200es Big Red
    Nov 2002
    1,189
    it could be a 84, but my dad said that it is most likely a 83. on the model # it says ytm-200e. btw, the frame number is 24w-005294 there is another one of these "mystery machines" around somewhere where i live, but i haven't tracked it down yet.
    My Rides
    Yamaha 200E
