Results 1 to 7 of 7
Thread: 84 R Question
    Tionesta, PA
    5,743
    84 R Question
    Will the engine come out of a 1984 250R without pulling the swing arm bolt out? I have all the bolts out of the engine mounts, and the whole top end off the motor, and I still can't get it out. Help!
    Howard's Avatar
    Howard is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Memphis, Tn
    288
    no, on the 84 that swing arm bolt goes through the very back of the motor case. can't get it out without taking the bolt out.
    1985 250ES ATC
    1985 200X ATC
    1984 250R ATC
    1983 LT-50
    1991 LT-80
    1996 YFB-250
    >->->->Hgoody77@yahoo.com
    CUYAHOGA FALLS, OHIO
    1,242
    yup
    He's rite tim. Yanker out
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    Tionesta, PA
    5,743
    Problem is - it is siezed big-time...... Is cutting it the only way to get it out? How have some of you guys dealt with frozen swinger bolts?
    Howard's Avatar
    Memphis, Tn
    288
    any of mine htat have been some what frozen would never come out until i cut it.
    1985 250ES ATC
    1985 200X ATC
    1984 250R ATC
    1983 LT-50
    1991 LT-80
    1996 YFB-250
    Tionesta, PA
    5,743
    Howard -
    where did you cut it, and how? I am thinking a saws-all with a long blade - but what are the access points? Do you needa special blade for the hardened bolt? It looks like I will have to cut it in 4 places? is this true? Please let me know.
    Howard's Avatar
    Memphis, Tn
    288
    from what i member on the air fooler just every spot you can get a blade in, yeah sawzall.
    1985 250ES ATC
    1985 200X ATC
    1984 250R ATC
    1983 LT-50
    1991 LT-80
    1996 YFB-250
