I forgot to put the chain gasket in between the head and the cylinder in my 79. So what I did was remover the cam chain tensioner, got a screw driver and put as much slack as I could in the chain,remove the right side of the head, then get medium size flat screw driver and take rocker arms off the cam, then you might have to get medium length screw driver and put it in the end camshaft (leftside) and pull it forward and get another screwdriver and push the cam gear away from the cam and it should come out. I hope this helps you.
1979 Honda 110 ATC, CEET gas tank cover, 25X11X9 rear tires
1984 Honda 110 ATC, orignal blue plastics,
1982 Yamaha 175 TRI-MOTO, 26MM Mikuni
Honda US90 ATC, Collecting Dust
2004 TRX450R
