Results 1 to 15 of 24
Thread: Lights on the Z
    Sep 2006
    UK
    31
    Lights on the Z
    hi there, i havent got any lights on my triz but would like to get hold of some originals, i can source them but would need some help with the understanding of wiring them up, other than being without lights the Z is completely standard
    what im after is info on how i can connect the lights, battery and switchgear up together, will the battery charge while the engine is running,
    winters on its way in the UK and it will soon be dark at 4pm which makes riding after work a bit difficult, fun but difficult , as ive found with friends,
    many thanks
    James
    Tri Z 250 1985
    Honda CR 250 1994
    Nissan Skyline GTSt R33 300hp 1994
    Need More Toys
    Northern CA
    1,104
    Try this....http://www.yamaha-motor.com/sport/parts/home.aspx
    Its not a very good Picture but might give you an Idea...If no one Copies one out of the manual today I will dig mine out of the Trailer and Post it for you
    Also,,,There is no Battery
    85' Tri-Z 250
    85' Drag Tri-Z, BBBBBRRRRRAAAAAPPPP!!!
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    87 Ninja750 3wheeler
    Sep 2006
    UK
    31
    wow, amazing little site there, but i couldnt see anything about the wiring or how to do it, great no battery, id presume most of the wiring is still there but i will need switchgear, ive got some cables taped up with duct tape so im hoping thats the part of the loom i need,
    many thanks
    James
    Tri Z 250 1985
    Honda CR 250 1994
    Need More Toys
    Northern CA
    1,104
    You couldnt see anything????
    Ok,,,,Let me know if this helps.....
    85' Tri-Z 250
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    Sep 2006
    UK
    31
    sorry, my fault, i must have gone straight passed it, im pretty sure my lighting side of the loom is taped up, i cant check untill tomorrow as the Tri Z is at work, but my switchgear doesnt look to good, is all switchgear universal ?, a friend has some off a GPZ i could have if so
    James
    Tri Z 250 1985
    Honda CR 250 1994
    Need More Toys
    Aug 2006
    Yorkshire & Norfolk UK
    49
    jleggz
    Check out the electrical section of www.dirtbikestore.com - they have universal switches and the like.
    ML
    TDR250 - mint Jap imort
    XR200R - mine since 1990
    110 Monkey Bike - For Sale
    1980 ATC110
    Polaris Pro1200
    Kawi 550SX
    Jeep Wrangler TJ
    'Real' Mini Cooper - For Sale
    I hope my missus never sees this
    na
    5,702
    On the 3WW homepage,there is a link to the right hand side that says SPECIFICATIONS.Click that and then go to wiring diagrams.There is a color coded wiring diagram for the TRI-Z.Yellow and green are hot and black is your ground.Make sure you have your voltage regulator hooked up.It is on the right side of the bike just behind the forks.There should be a silver box with one blue wire coming out.If it is not there,you will blow your bulbs out.Banshee,and blaster use the same style regulator.
    Proudly NOT a member of
    "Team on the Teat"
    Sep 2006
    UK
    31
    thanks mosh, yeah the regulator is there, thanks for the link, will now check it out, i just need some lights, ive got the casing but no lights in there, hopefully some will come up or il get some universal lights
    many thanks
    James
    Tri Z 250 1985
    Honda CR 250 1994
    Need More Toys
    Front royal, va
    2,186
    james, you need lights from a 200 kawi bayou 220 four wheeler, they are the same as the z, mount the same, and use the same plugs, plus they cost less new
    Watertown, New York 13601
    3,382
    Quote Originally Posted by 03 ORANGE SHEE
    They sure do!!!!!!
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    older warrior with the square lites are too!
    na
    5,702
    head lights
    hey jleggz.if you run into a hard time gettin lenses and such,drop me a p.m. i can probably help you out.and Raffa is correct,any older warrior with stock square headlites,will work.electrical sockets bulbs and lenses will all "bolt right up".i think they came on 87-89 warriors.maybe even 1990 years also.
    "Team on the Teat"
    87 warrior light assm. $27.07 new
    86 tri z light assm. $68.71 new
    the only diffrence is the warrior has a 25W bulb,, but the z's 30w bulbs will fit.
    89 kaw bayou 220 assm. $138.57 new
    bulb plug is diffrent and harness plug so it would have to be hard wired
    The lense is the same shape but will need the plug.
    3,382
    I use new 2002 220 bayou lights on my Z and they bolted right in. They were half the price of new Z lights.
    2006 YFZ 450
    what did you do for the plug for the harness?
    2002 $36.51 thats still better than stock
    wonder why the 89 is so mutch it looks the same...
