I finally got the 110 running earlier by pulling it with my 4 wheeler. It cranked up twice out of about 10 tries.
The first time it cranked it sounded good, no smoke but it acted like the clutch was slipping, then died a minute or so later. It took several more tries with choke on and off and cranked again. This time my bro got it in neutral (I was pulling). It idled real good for a couple of minutes then died again before I could reach the choke. I had cleaned the carb earlier but it was surprisingly very clean, jets, etc.
Here is the main problem. It will only shift DOWN when in the LOW setting. When put it HIGH it only shifts into one gear and it a pain getting it back in neutral.
Could the clutch just need adjusting or does it sound like a major tranny problem?
I am trying to get this 110 running for my little boy.
I really don't care about HIGH gear, but I don't understand the shift pattern where neutral is all the way UP, and you shift DOWN. I thought the pattern for the 110 was 1st down, up one neutral, rest up, just like a bike.
By the way this is a 1980 model.
and it turns while while it is being hit.
