Results 1 to 10 of 10
Thread: Throttle Stuck
    smyers33 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Tennessee
    416
    Throttle Stuck
    Just got my 200x back together, but when I start it, it's like I have the throttle pinned. There was to much play in my throttle so I fixed that but it still revs like at wot. It has to be something with my carb, or where I hook the throttle up to the carb. I can go ride when I get this fixed. Any body know whats up?
    1983 250r
    1986 200x
    1985 250sx
    Columbia
    5,131
    Idle screw?
    I adjust my idle screw frequently with my Warrior, its a weird bike.
    Also, sure you got the right length cable?
    Ontario, Canada
    457
    also, is the carb slide seated properly? with the engine off, turn it wide open and let go, you should hear the slide snap back down (bottom out)
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    Jul 2006
    Tennessee
    416
    I have had the throttle screw totally in and the farthest out I could get it and it still didn't make a difference... I check about the slide. I am currently reading my service manuel.
    1983 250r
    1986 200x
    1985 250sx
    ovhonda1's Avatar
    ovhonda1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2005
    Louisville, KY
    369
    take your carb slide out and turn it until it seats correctly. I had myine in backwards and it did the same thing. good luck.
    Ontario, Canada
    457
    lol Oh right if it was in backwards it would still bottom out, just not as loud i guess....D'oH!
    '85 ATC 250R
    Boyesen Rad Valve
    38 PWK A/S
    13/36 sprockets
    '85 ATC 250R
    Jul 2006
    Tennessee
    416
    I got it... thanks for the help the slide wasn't seated correctly like you said. Thanks again. Now I got to deal with the chain popping off. It was loose, now it's tighter than a nun... so I think its the front sprocket. If the front sprocket quite a bit of play, will that cause it?
    1983 250r
    1986 200x
    1985 250sx
    Ontario, Canada
    457
    ooo i'm scared to diagnose that one.....well its either lackin a spacer or the bearings are going...could also just be sloppy on the shaft, would mean new sproket
    does the shaft move when the sprokt moves?
    OH some guide lines, the chain should have a total of an inch of play on the bottom run if you move it up and down, well with you sitting on the trike 1/2 inch.
    '85 ATC 250R
    Boyesen Rad Valve
    38 PWK A/S
    13/36 sprockets
    '85 ATC 250R
    Aug 2006
    The splines may be shot on the shaft.. that's not a good feeling
    1985 350X
    1986 250ES Big Red
    (previously owned) '89 Cr 250R
    2008 Toyota Tacoma Double Cab
    Jul 2006
    Tennessee
    416
    I got it fixed... the front sprocket had too much play.. I tightened it, and it doesn't happen as often. Only when I like pin it in second to slide around.
    1983 250r
    1986 200x
    1985 250sx
