it would add weight but i was gonna do it that way b/c its seems like the cheapest way. i got the motor to do it. its a honda 5.5. it came off a pressure washer.
Definatly the cheapest way to do it.
the only other way i could come up with was the bikes motor turns a gearbox in the rear with a 2 way split one for the rear wheels then the other drive shaft powers the front.
savin one atc at a time
I dont know if it would work but??? Get two identical hydraulic motors and run one to rear axle and other to front, plumb them together and it seems that the rear axle would turn the motor which should pump fluid to the front motor. Seems to easy though so might not work.
i guess You cant have to many parts though, to many things to go wrong.
Sketchy on the details, But think about a shaft driven yammy --Backwards?
Buy American! Unless your only option is a HARLEY.
A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
Originally Posted by xljimmy
i like this idea![]()
Yeaa I was thinkin of the Rokon bike also. I remember seeing those in Dirt Bike Mag a few years back... I've never actually saw a real, live one.
1985 350X
1986 250ES Big Red
(previously owned) '89 Cr 250R
2008 Toyota Tacoma Double Cab
I've given this much thought. It can be done using a 4WD shaft driven power trane. Using the front shaft to connect to a box at forks. Then come down forks with shaft with long yoke to allow shocks to be functional too. Rear could be shaft as well.
You may have given me a good idea to put this polaris 500HO engine and tranny to good use.Almost anything can be done. You just want to WANT to do it.
yamaha built a yzf426 i think it was with a hydraulic front wheel drive....but anyways, you guys are crazy, think SIMPLE! take a rokon and put an axle on the back, its chain drive in the back! DONE!
yes yamaha made a 426 or 450 2 wheel drive which has already won some desert races, they also made a 2 wheel drive R1 superbike which was apparently awesome in wet conditions, i think they made it with ohlins (who they own i think).
i also had a look on the net and found this modified crf250, check it out.
http://www.christini.com/news-press-10192005.php?id=m
looks like they make a universal kit, maybe someone could use it on a trike.
steve.
HONDA ATC250ESJ 1988
HONDA 250R `85 restored SOLD
HONDA ATC 350X `86 restored SOLD
HONDA ATC 250ES `87 SOLD
YAMAHA YZ100 `80 project
HONDA ATC350X `85 PROJECT FINISHED
Each day the topics get even more dumb on this site. There should be a minimum age to log on. Buy a 4x4 quad !!
here is some video and pictures of 2wd motorcycle
http://www.christini.com/motorcycle/...es-photo-m.php
1985 250ES ATC
1985 200X ATC
1984 250R ATC
1983 LT-50
1991 LT-80
1996 YFB-250
>->->->Hgoody77@yahoo.com
there's a much easier way...
you don't need the 3rd wheel engaged all the time, just when you really want it.
use a strong electric motor, like a starter motor, or a smaller one will work if its geared well (like a winch).
i rigged one up with a 12volt motor from a drill. it turned the wheel, but wasn't enough power. the starter motor would for sure do it though. an added plus would be if you switch the polarity, you've got yourself reverse then too.
should be a competition to see who can get the first real prototype working here!
tha bike was SICK!!
