Can I put a 200m engine in a 185s frame? I figure the starter motor will get in the way but by how much? Could I just dent the frame to make the clearance I would need?
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
yep it should fit im about 85.9%sure
It can work,you just need to dent the frame where the starter goes. You'll need to make a battery box, mabey on the frame under the grab bar.
TF 07,08,09,10,11,12,13,14!
I have done this swap. You can either remove the starter motor or dent the frame. A very slight dent in the frame is all that's required.
hope this helps ya.
Cool that is what I needed to know. Thanks guys!
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
