Originally Posted by
burnoutboy
Could be worn rocker arms??
Bingo, we have a winner!
The rocker arms do tend to wear out on these things. If you pull the arms out you will see a little flat spot starting to develop where the arm rides the cam, just off center. If it is a light tick and it doesn't bother you too much then I wouldn't worry about it, just keep the valves adjusted. The inside cam journal does wear out too on "well used" machines but that makes a louder knocking sound.
When the primary clutch goes it usually is the one way bearing as Yamahauler stated. When my brother’s was bad he would have to rev up the trike a little more to engage the clutch.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
