Results 1 to 15 of 26
Thread: ok.. Ytm 200 questions
    Dec 2005
    Wisconsin
    1,141
    Ok I put a new air filter on it. UNI yellow, and red foam, on the stock cage thing. What color am I looking for in the plug. Is it the same as reading a 2 stroke. cause I can read them fine, just I havent ever really paid much attention to 4 stroke plugs...
    I adjusted the valves on it today, they are all in spec now, runs good. But I still have a ticking sound when it gets hot. Not rod knock, sounds like something in the overhead... Mabee the rockers? idk any ideas?
    Thats it for now. Thanks.
    Brandon, Manitoba
    2,209
    should be a lite tan color.
    Did you adjust your valves with the engine at operating temp?
    Dec 2005
    Wisconsin
    1,141
    Ok so the plugs are pretty much the same as a 2 stroke then? light golden tan is good.
    I adjusted the valves when the engine was cold. That what it said in the manual. Also I set them in the middle of the tolerances.
    Brandon, Manitoba
    2,209
    I always have trouble with valves. It seems you have to set them right at minumum tolerance or else they tick, and after i ride for about 10 hours, they start ticking again so i readjust
    Dec 2005
    Wisconsin
    1,141
    humm mabee I will set them a bit tighter. the exhaust seemed good but the intake had a bit more free play in it. Thats the one that sounded loud when I put a screwdriver on the head, and put my ear up to it.
    also which clutch goes first the primary or the secondary? Mine slips a bit taking off when its warm I would think the primary. Its adjusted right too.
    Thanks yamahauler.
    Brandon, Manitoba
    2,209
    The primary and secondary clutch go at the same time....have you tried the adjuster screw on the right hand side of the case?
    if that still doesnt work, make sure you have the right oil in it.
    if that doesnt help, you may need new friction plates, which are easy to change.
    i am almost sure my manual says adjust valves with motor hot, im going to check.
    Brandon, Manitoba
    2,209
    Woaa....valves ARE supposed to be adjusted cold....sorry bout that.
    Dec 2005
    Wisconsin
    1,141
    Yep I adjusted the little set screw with the stop nut on it, as the book said. Counter clockwise untill friction is felt, then clockwise 1/8 of a turn.
    Yeah I run spectro 4 15-40 for winter, I just changed it this week when i did the air filter.
    I noticed I can get friction plates for the secondary, but I cant find any parts for the primary.
    Mabee I will have to find on in the junk yard and give it a try...
    Brandon, Manitoba
    2,209
    You wont need to put new shoes or anything on the primary, all ive ever seen or heard of going bad with primarys is the one way bearing, but that doesnt affect clutch slippage at all. Is that a synthetic oil?
    Dec 2005
    Wisconsin
    1,141
    petroleum based oil
    troy's Avatar
    troy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2006
    Canada
    254
    when you find a way to get the ticking out let me know..I changed the head on my 200ERN and it ticks, i'v done every thing to get rid of it but it won't go away. NOW, a few people around here with yamaha bikes seem to do the same thing. So i dunno what to say. I know mine didn't tick with the old head on it
    burnoutboy's Avatar
    burnoutboy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    New Zealand.
    352
    Could be worn rocker arms??
    mark38090's Avatar
    mark38090 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Hawthorne, Florida
    354
    Mine ticks too... Must be Yamaha signature!!!
    1984 Honda TRX200
    1985 Yamaha 200ERN ( two of these now)
    1985 Honda 250SX
    1991 Suzuki LT230
    2003 Honda Rancher 350ES
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by burnoutboy
    Bingo, we have a winner!
    The rocker arms do tend to wear out on these things. If you pull the arms out you will see a little flat spot starting to develop where the arm rides the cam, just off center. If it is a light tick and it doesn't bother you too much then I wouldn't worry about it, just keep the valves adjusted. The inside cam journal does wear out too on "well used" machines but that makes a louder knocking sound.
    When the primary clutch goes it usually is the one way bearing as Yamahauler stated. When my brother’s was bad he would have to rev up the trike a little more to engage the clutch.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    troy's Avatar
    Aug 2006
    Canada
    254
    WOOOOWOOO HOLD IT HOOOOOLD IT..your saying it's the rocker arms...HUMMM ... So if i take the arms out of the old head i got here and put it in the one i just put on it, it will *Edited**Edited**Edited**Edited* it up from ticking?...if so, while i have the top end striped down this winter i will change them. Because this bike made NO ( and i stress NO alot here) ticking at all till i changed the head. and yes it's one of those noises that drives me nuts
    because i'm starting to think this bike wasn't used very much in the past, execpt for the last 7 to 8 years when a 12 year old bought it, then was sold to some one else who used three or four time then i bought it. The original owner was a old guy.
