So I just bought this 350x that I'm told had a new high compression piston in it. It seems to ride fine, but not as fast as I'd like, (only hit 55mph on it) so I go to check the oil. First, I pull the oil cap off while the engine is running, not to check, but just to see what happens. As soon as I do, its blowing out what feels like exhaust out of the oil filler hole, I didn't smell it, but its under quite some pressure.
Does this mean my rings are beyond shot? Is this hurting something on the lower end (probably gaskets hey)?
My guess is a high comp piston was put in at a standard size, with a worn cylinder.
Its a LOT of pressure though, and seems to run alright.
Any ideas?
